yes again.....trouble....misfire at wot....
Posted: Thu Aug 11, 2011 7:44 pm
i re did my intake windows and went alittle too deep on bottom.........
put hole in bottom of block/ window... jb weld marine cold welded it. Seems to run fine till im wot/going fast it misses like timing is off not really a bog..... had it tune good before .... i re checked the area and put a 2nd and 3rd coat to be sure,,,,, put a leaner jet same, put a richer jet same problem???? will run it tomarrow when 2nd 3rd coat dries.....
