21mmcarb taz kit 48mm bbk taz kit premix jetting
Ratrod
Post by Ratrod »
1987 spree 21mm carb 48mm bbk.all taz gear.running 32:1 premix , no pump. issue is with idle and ridding close to 1/4 throttle. i got a 92 main witch seems to be good ..a 38 pilot thats seems to be rich ..im gonna move down to a 35. maybe even a 32.. i was wondering if anyone has gone that far down on a pilot befrore.also when i open the choke it revs like a bat out of *,,,
RATROD
86 stock spree
87 spree 48 bbk, carb, pipe
Re: 21mmcarb taz kit 48mm bbk taz kit premix jetting
Do a plug chop at the speed you have issues with and see whether you are rich or lean, guessing waste time.
My advice:
When in doubt, Richen. Try a 42 first.
If it's worse, then go down.
Make Sure there are no vacuum leaks for sure. Running better on Choke suggests it's Way lean.
jokim00
Post by jokim00 »
So did you find the right mix?
I would like to know what sizes you ended up using if you dont mind.
I plan on doing the same thing with my spree.
Also, whats your top speed and how much do you weight?
Red 1986 Spree
jokim00 wrote:So did you find the right mix?
What is this insane worry about rider weight and top speed? The weight may effect acceleration but the difference in top speed will not be enough to measure. :eyeroll:
jokim00
Post by jokim00 »
Haha ok.
All I wanted to do was ask for the top speed and to get a relative sense of it all but you're right.
Hope you found your right mix.
Red 1986 Spree
