21mm spree carb kit results
ascmlaren53074
Post by ascmlaren53074 »
hi, just in the process of installing my 21mm carb/intake kit for the spree,i have a the 48mm bbk and gears already installed,what kind of results should i expect,thanks
1986 spree,48mm bbk,2.75 rear tire,aero 50 front turn signals,1987 front glovebox add on,uni pod filter,taz's gear set on the way
Re: 21mm spree carb kit results
Taz has one put together and running.
