dun rite
Posts: 662 Joined: Fri Apr 15, 2011 2:07 pm
Post
by dun rite » Wed Aug 17, 2011 12:57 am
well done looks good. I see you have the same little pin holes in the aluminum as I had. they had me worried at first
not sure what else you can or should do.
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
mopro logan
Posts: 123 Joined: Thu May 26, 2011 4:52 am
Post
by mopro logan » Wed Aug 17, 2011 1:17 am
dun rite wrote: well done looks good. I see you have the same little pin holes in the aluminum as I had. they had me worried at first
Yeah the pin holes are just casting marks I think. I was looking at them at first to. I am still not sure on what size carb. Thanks
Petrock's 1984 Spree
Posts: 730 Joined: Wed Dec 01, 2010 10:20 pm
Post
by Petrock's 1984 Spree » Wed Aug 17, 2011 8:37 pm
mopro logan wrote: dun rite wrote: well done looks good. I see you have the same little pin holes in the aluminum as I had. they had me worried at first
It all depends on what your scoot's mission in life is. I still wanted alright fuel economy so i went with a small carb.
If you want a flat out dragster with a giant exhaust then the 28-33mm carbs seem to be the way most people are going
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
maddog
Posts: 2171 Joined: Mon Jul 23, 1973 10:24 am
Post
by maddog » Wed Aug 17, 2011 8:47 pm
so now its ported= now tell us what else needs to be done
Posts: 5013 Joined: Tue Jul 14, 2009 7:53 pm
Post
by Trafficjamz » Wed Aug 17, 2011 11:17 pm
The 24 or 21 would be a good choice.
Posts: 9244 Joined: Mon Jul 23, 1973 10:24 am
Post
by Bear45-70 » Wed Aug 17, 2011 11:52 pm
Trafficjamz wrote: The 24 or 21 would be a good choice.
+1
mopro logan
Post
by mopro logan » Sun Aug 21, 2011 11:33 pm
Thanks for the help I was thinking about a 21 also.
Posts: 10683 Joined: Wed Oct 22, 2008 5:09 pm
Post
by Wheelman-111 » Mon Aug 22, 2011 9:34 am
Hit up the ever-helpful Z50R-Ghost. He's actually built and tuned an OKO 21 on his setup, evidently with good results. Most subscribe to the "Bigger is Better" mantra.
Post
by Wheelman-111 » Mon Aug 22, 2011 5:26 pm
OOOoooh, AAAaaah,
Shiny !
Be sure to remove that hex bolt from your tranny vent before a long ride, though. Firing projectiles at following
Gendarmes is frowned upon, even here in Texas.
Post
by Trafficjamz » Mon Aug 22, 2011 9:34 pm
did you for get to put in a wrist pin clip
I spy one on the table
How did you get your wife to let you put that together on the kitchen table
mopro logan
Post
by mopro logan » Tue Aug 23, 2011 4:07 pm
No did not forget the wrist pin clips and as it goes for putting it together I could have done it on the bed and she wouldn't have seed nothing.
mopro logan
Post
by mopro logan » Fri Aug 26, 2011 12:38 am
I am going for a daily driver and a fun time at the drag races. All and all just a fun little ride.
mopro logan
Post
by mopro logan » Tue Aug 30, 2011 10:10 pm
Started panting my frame today and this is what I got done so far. What do you think?
