ignition diagnostics
Posted: Fri Nov 26, 2004 10:29 am
by mikehailwood
My 1984 Spree has no spark. New plug does not help. Where can I find a systematic process for diagnosing the sparking system?
Mike
Posted: Fri Nov 26, 2004 2:53 pm
by jimpomm
Noiseguy provided this link in another section of this site .Download and scroll to proper section -excellent link with troubleshooting sections
http://www.hondaspree.net/other/Spree_s ... manual.pdf
Posted: Sat Nov 27, 2004 12:20 am
by Jim
If its not the plug, its probobly the coil.
Posted: Sat Nov 27, 2004 12:36 am
by Tippmann98
yeah, that happened to one i worked on. I would try swapping it with a working used one if you can get it cheap. Its not a hard switch.
Posted: Sun Nov 28, 2004 5:46 pm
by Jerry
Read the repair manual. There should be no need to swap parts with used or known good ones if you take a few minutes and properly troubleshoot the systems.
A simple multimeter (Radio Shack $5) is all you need. By the sound of what this person is asking, the CDI unit may be the place to start and even then it could just be a broken wire. A simple ohm test (continuity) on the coil will alleviate any possible accusations.
Like anytime you're troubleshooting:
Start with the most simple and logical.
Sparkplug
Coil (including the spark plug cap may be loose)
CDI unit
Trigger coil
And above all - the wiring between all these units. Step by step and you can find the problem in less than 10 minutes.
Posted: Fri Jan 28, 2005 7:34 pm
by mikehailwood
Thanks to jimpomm, Jim, Tippmann98 and Jerry for providing ideas. See exciter coil resistance for additional discussion of my problem. See wiring at CDI for final resolution of my "no spark" Spree. Thanks again to all. Mike
