Help need a part number 2000 elite gasket
Palero2003
Post by Palero2003 »
well trying to get a freaking gasket at local Honda place. well guy I talked to on the phone says there is no gears in scoot blahhhhh. anyways I need a part number for a 2000 Honda elite s gasket the one for the gears. The one that take clutch off remove other screws tap the small cover off and then there's gears.
any help will be greatly appreciated
thanks
also did search but couldn't find part number just reffrance saying need it as a spacer also.
ERROR 1604
Re: Help need a part number 2000 elite gasket
Hmm,
Honda parts guy should have done a little more searching.. Will post a diagram shortly so you may confirm its the part you want
11396-GR1-020 GASKET, L. RR. SIDE COVER
Palero2003
no not that one the other one behind clutch. holds the gear oil and stuff.
ERROR 1604
Sorry,
GASKET, TRANS CVR
21395-GBL-870
Here's a link so you can do more searching...
Online Parts Fiche
Palero2003
ty that's what I need off to the Honda dealer hope don't talk to the * again!!
ERROR 1604
Find and save a Dealer Parts Fiche to your Favorites, and never be Clueless again! :wink:
Palero2003
LOL went to one Honda place with the retard earlier. they said they could order it. be about 2 weeks drove another 30mins to another place which they had it and put it up front for me. they actually have workers with a clue. LOL part number prolly helped also. God what a freaking mess inside trans cover oil everywhere!! broke a bolt off then broke extractor in it. drilled completely out retapped and couldn't find a bolt with a small enough head kept hitting clutch so quick steeled the hole :( and tapped it. went ridding with a buddy checked for leaks a couple times and nothing leave the scoot at home take the car out come back 3 hrs later and a small little puddle errrrrrrr. Been a crappy day LOL.
ERROR 1604
