86' spree: Low end power
Spree<3
Post by Spree<3 »
Any ideas on ways to improve my low end power? Take off is very slugish and I want more :smile:
1986 Spree
sprite2011
Re: 86' spree: Low end power
Post by sprite2011 »
Lose 3/4's of your weight or do a motor swap.
SuprasNsprees
Post by SuprasNsprees »
is it properly tuned ?
mine had a HUGE lean spot from about 5-15mph, untill i figured out the idle and mixture settings better
'80 Puch Magnum MKII
'78 PA50 Hobbit
Spree<3
Post by Spree<3 »
Just lost 20 lbs... but doubt I'll be able to get down to 46 lbs any time soon. :smile:
I have it tuned pretty good. Just changed belt and did a full carb clean...helped mid and high,but low is same.
No mods that will help - other than Dio swap?
1986 Spree
.....Hey,...Spree<3....let some skinny, trustworthy, friend ride it and see how it does....I weigh 195 now and have seen 225 as well as 165,......Little Spree run sluggish take-off when I'm 200+...OK when 195-175.....much better under 165..... :hi:
Spree<3
Post by Spree<3 »
Trustworthy friends?? Where do I find one of those? :wink:
I'm at about 175 and its not doing well untill I hit about 12mph. My daughter - at 110 - rode it and it was still very slow on take off. And uphill... fegedaboudit. Unfortunately, I live in a hilly area :sad:
I'll have to check my airbox/intake again... make sure I got it hooked up tight.
1986 Spree
Spree's have low end power? Since when?
Get a big block and the carb, intake and adapter from Tazland001. Other than that you are NOT gonna have low end power with a Spree. Or get a variated engine and swap it in to the Spree.
martynkim
Post by martynkim »
Bear45-70 wrote:Spree's have low end power? Since when?
OH YEAH!
