muggy weld sucks!!!!! do not buy....
Pancake808
Post by Pancake808 »
will not fix crap, it is crap, as seen on tv bs... same as other fakes.....so if u read this save your money !!!!!!!!!!!!!!!!
killerpancake
Re: muggy weld sucks!!!!! do not buy....
Post by killerpancake »
muggy weld? never even heard of it. most things that say "as seen on tv" suck.
(Previous)
87 honda spree
85 honda spree
(Current)
88 yammy razz
(parts bike)
another 88 yammy razz
richdavison34
Post by richdavison34 »
If you need something welded, my services are available.
1984 Honda Aero 50.
Carb Swap. Cone filter.
What are you repairing:?:
www.muggyweld.com Is this feedback on the aluminum solder or 'welding rod'?
dun rite
Post by dun rite »
have used the muggy solder and have found things have to be super clean. have repaired float bowl holes and radiator problems with it. never tried to fix anything that need super strength.
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
