possibility of putting manual choke on 87 elite s?
killerpancake
Post by killerpancake »
Put new rings on this bike, along with new headgasket and new base gasket. Was starting up perfectly, but it's beginning to give the same problems as before, being that it won't start after it had been sitting, the autochoke(bystarter) has been replaced many times with new ones, i need to know the possibility of finding a manual choke for the 87 elite.
(Previous)
87 honda spree
85 honda spree
(Current)
88 yammy razz
(parts bike)
another 88 yammy razz
dun rite
Re: possibility of putting manual choke on 87 elite s?
Post by dun rite »
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
Mystic
Post by Mystic »
I think they sell manual chokes for the deltorro carbs that will fit, there was a thread about it but cant remeber exactly what it was
Mystic
Post by Mystic »
lol guess i should have looked at your link dun rite :D that was the one
killerpancake
thanks for the link, that looks just like what im looking for... that may be kind of a pain to flip into the choke position being under the panel, But hey it's worth a shot. Thanks.
(Previous)
87 honda spree
85 honda spree
(Current)
88 yammy razz
(parts bike)
dun rite
Post by dun rite »
make a bracket of the carb (somehow) and use an old choke cable, the one that is wire inside not cable. could route it to the headset.
arreche air filter
v8 pipe
stock gears
maddog
Post by maddog »
yes polini makes a 19mm intake adaptor along with a 19mm carb and your choice of a lever/ plunger or cable choke, i have all 3 types mounted :smile:
killerpancake
maddog wrote:yes polini makes a 19mm intake adaptor along with a 19mm carb and your choice of a lever/ plunger or cable choke, i have all 3 types mounted :smile:
on the same bike? :bowrofl:
(Previous)
87 honda spree
85 honda spree
(Current)
88 yammy razz
(parts bike)
