Honda Tact
Honda Tact
Rough running Tact. replaced roller weights 12grams and belt. improved running,applied grease to the weights. Experienced low fuel supply due to kink hose. Flooding of carb due to dirt from the tank. Installed filter but results to kink hose so removed filter.
Re: Honda Tact
Umm, O-Kay...
Umm, O-Kay...
Re: Honda Tact
+1Wheelman-111 wrote:Greetings:
Umm, O-Kay...
I don't mod my scooters to go Fast, just want to keep it running!
87 Elite SE50
86 Elite CH150
98 Yamaha Zuma 50cc
87 Elite SE50
86 Elite CH150
98 Yamaha Zuma 50cc
- the0captain
Re: Honda Tact
3 fuel issues - How often does that happen?Experienced low fuel supply due to kink hose. Flooding of carb due to dirt from the tank. Installed filter but results to kink hose so removed filter.
So how's it running now, and we need to see pics
Re: Honda Tact
My Tact now runs better. i experienced replacement of belt two times. maybe due to roughness of the driven face of the variator.I still can post pics. tried attaching files but to no avail.
- swimmingfree
Re: Honda Tact
a lot of us use ImageShack for are photo
- Munstah666
- Goped
Re: Honda Tact
If he's got the Tact Fullmark that is a DIO, but couldn't quite understand exactly his issues? Sharing or Askingthe0captain wrote:
µùѵ£¼Òü«Òé╣Òâ╝ÒâæÒâ╝Òâ×Òâ│
- martynkim
Re: Honda Tact
Munstah666 wrote:If he's got the Tact Fullmark that is a DIO, but couldn't quite understand exactly his issues? Sharing or Askingthe0captain wrote:
This all depends on the year of the bike.
Re: Honda Tact
Don't overlook the totally obvious: 2-strokes don't run worth a crap on green gas (10% ethanol). Try a tankful of no-ethanol. It doesn't cost you anything to try it and you'll be surprised at the difference.funplanet wrote:Rough running Tact. replaced roller weights 12grams and belt. improved running,applied grease to the weights. Experienced low fuel supply due to kink hose. Flooding of carb due to dirt from the tank. Installed filter but results to kink hose so removed filter.
