85 spree cold start problems
starsnbars
Post by starsnbars »
my 85 spree had problems starting when it hasn't been run in a while I have to kick start it for at least 20 min and then it starts to fire. Once this thing gets going it runs perfect, and can start first crank when its been running for a while. Compression is 110+, good spark, and i can drain fuel out of the carb from the float screw after a crank or two.
Bystarter problem?
It's only been maybe 25 miles since I have rebuilt the carb and it has a brand new air filter.
Any insight is greatly appreciated guys!
dun rite
Re: 85 spree cold start problems
Post by dun rite »
sounds like the bystarter. view this
http://hondaspree.net/wiki/index.php5?t ... at_It_Does
a the end of bystarter reassembly is a test procedure.
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
Sounds more like a low manifold vacuum or a shot petcock preventing a decent fuel supply while cranking.
martynkim
Post by martynkim »
starsnbars wrote:my 85 spree had problems starting when it hasn't been run in a while I have to kick start it for at least 20 min and then it starts to fire. Once this thing gets going it runs perfect, and can start first crank when its been running for a while. Compression is 110+, good spark, and i can drain fuel out of the carb from the float screw after a crank or two.
Bystarter problem?
Instead of kicking for that long try priming your carb first. If it starts likely a fuel issue. :smile:
