problems
Mike
problems
Post by Mike »
my airbox tube is nicely sealed around the carburetor but it still bogs out SOMETIMES. it is still getting too much air. i sealed alot of the air box so i dont know what else to do. please help me out
'86 Black/red two-tone Honda Spree, pretty much stock.
Is the heat insulator (plastic bit b/t the carb and manifold) in the right way? Orings should not be touching, make sure it's not upside down and not sealing.
Admin, Hondaspree.net
Mike
Post by Mike »
i have brand new o rings and insulator. the insulator IS on the right way. what do you mean when you say the o rings should not be touching?
MySpree
Post by MySpree »
the o ring should ber faceing the manifold... and how ur bystarter sealing?
Mike
Post by Mike »
o okay then yeah the insulator is on the right way. i have new o rings on the bystarer too. in fact all the carb o rings are new i just replaced them.
MySpree
Post by MySpree »
maby there is a hole in the airbox someware...
darat
Post by darat »
or u have a cracked carb?
MySpree
Post by MySpree »
or ur intake is leaking were it mounts onto the base
Mike
Post by Mike »
MySpree wrote:or ur intake is leaking were it mounts onto the base
i have that sealed. im gonna try and figure whats up with it today
MySpree
Post by MySpree »
is your oil line on?
Mike
Post by Mike »
i found a nice new vacuum tube with a VERY tight fit and now itst working alot better so the spree is good to go. thanks guys.
MySpree
Post by MySpree »
good to hear
