I see the vacuum hose on the engine side of the carb, and assume that once the engine is going, we have some vacuum, and that opens the valve, and then gas drops into the carb, and by magic, it mixes with air goes into the engine, and it stays running...
But what about if the motor won't start? With just the starter turning the motor, how is there still enough suction to pull gas into the carb, and then into the engine?
