1987 honda elite SE50 ramp plate
honda elite SE50
Post by honda elite SE50 »
Hello how much speed will I gain if I get an unrestricted ramp plate for my 1987 Honda elite SE50
Re: 1987 honda elite SE50 ramp plate
Honda restricted the speed of the SE50 "P" Elite to comply with some States' rules about a 25-MPH maximum speed to qualify as a "Moped". Meanwhile the SE 50 Elite S from 1987 is capable of ~40 miles per hour. Yours can get to that speed with very little work. The ramp plate is a good start.
There is more than one measure restricting the "P"s, however. You are correct that the ramp plate is an important factor. However the exhaust pipe may be another. If you dismount the pipe, look for a diameter-narrowing washer in the head pipe. (I've never actually seen one, but others can advise...). Get to work with a small grinding bit and eliminate that constriction. Some have reported some sort of blocking plate under the intake manifold as well. Perhaps get advice from fellow SE owners.
Finally, once the engine has been unshackled from the rev-limiting exhaust strangulation, look to increase the size of the carb's main jet. Your Elite might have a #68 lurking in there. (Honda's parts fiche says "82 or 85" but I think it's wrong...Check to be SURE!) The Unrestricted models had an 85 - personally verified. DO NOT run the scooter sans restrictions without upping the jet to that size, lest it breathe vapoures excessively lean, overheat and calamitous consequences ensue.
evilone
Post by evilone »
Wheelman-111 wrote:If you dismount the pipe, look for a diameter-narrowing washer in the head pipe. (I've never actually seen one, but others can advise...). Get to work with a small grinding bit and eliminate that constriction.
There is no washer, the pipe diameter is the restriction. You need a different muffler.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
honda elite SE50
How much speed will I gain by just switching the plate?
Brivander
Post by Brivander »
honda elite SE50 wrote: Mon Sep 19, 2011 2:45 pm How much speed will I gain by just switching the plate?
Your link looks like the restricted version.
I believe 22131-GR1-010 is the non-restricted. You could probably just get the Keli Ramp plate, you can't tell the difference between it and the honda.
1985 Black/Purple Spree-39 GPS
1985 Red/White Spree-40 GPS
1987 Black/Purple Elite-44 GPS
1985 Red/Black Aero-42 GPS
1992 Red/Gray Jog- 56 GPS
nateberrier
Post by nateberrier »
i have like 4 stock aero variators if you want one. look for the KELI variators on ebay from fast2wheels they are like 40 bucks
1986 Aero White -- Stock With Keli Var
1985 Aero Red -- Af05 Malossi BBK + Keli Var
1985 Aero Red -- Af16 Corsa / Fabrizi Pipe / Polini 24 PWK / Athena Stuffer Crank
Brivander
Post by Brivander »
nateberrier wrote: Wed Oct 23, 2019 3:27 pm i have like 4 stock aero variators if you want one. look for the KELI variators on ebay from fast2wheels they are like 40 bucks
I think I bought the last one....
Honda50
Post by Honda50 »
The KELI variators I have found say they are for AF16, do they also fit variated AF05E?
Thanks!
Brivander
Post by Brivander »
Honda50 wrote: Thu Oct 24, 2019 7:35 am The KELI variators I have found say they are for AF16, do they also fit variated AF05E?
Thanks!
Not without modification, the slide is a larger diameter. I think AF0E is 12mm, Af16 is 14mm. Someone can correct me if that isn't right.
I would contact the seller and see if they have anymore. I may have actually bought the last one for my Aero. https://www.ebay.com/itm/85-87-Honda-Ae ... 2749.l2649
Brivander
Post by Brivander »
As a side note on this thread, the unrestricted version also has a different gear ratio 10.2:1 vs. 11.1:1. I'm getting 42 (I used the technigas pipe which is better than the unrestricted pipe, but not my much) before changing the gear ratio which should net 3-4 more mph.
sdugasjr
Post by sdugasjr »
Brivander wrote: Thu Oct 24, 2019 9:00 am As a side note on this thread, the unrestricted version also has a different gear ratio 10.2:1 vs. 11.1:1. I'm getting 42 (I used the technigas pipe which is better than the unrestricted pipe, but not my much) before changing the gear ratio which should net 3-4 more mph.
when you changed gear ratios, did you see any torque decrease off the line, while gaining top end? or vise versa?
thanks,
sidney
‘87 Elite SE50 - 72cc AF16
‘01 Elite SR
Brivander
Post by Brivander »
I upped the clutch springs, so it seemed better off the line.
