a couple questions on big bore kit (Spree)
B-Nasty
Post by B-Nasty »
OK, I received my 44mm big bore kit for my 86 spree. I cant tell a difference in the two rings, does it matter which ring goes on top/bottom or are they the same?
It states in the instructions, "if you add another gasket you will not need to machine the head"
It came with 2 paper gaskets (1 for the jug to case and another for head to jug) there is also an aluminum gasket for the head to jug. Will these 3 give me enough clearance between the head and piston so I dont have to machine the head? Of the paper and alum gasket that goes between the jug and head, which goes on top?
thanks!
Mystic
Re: a couple questions on big bore kit
Post by Mystic »
yes it matters which ring goes on top, the top ring is a tiny bit skinnier than bottom one, the bottom ring will not fit in the top . generally there will be a small T on the left ring gap denoting the top of the ring on both. if you install them upside down they may ruin your cylinder and break.
B-Nasty wrote:OK, I received my 44mm big bore kit for my 86 spree. I cant tell a difference in the two rings, does it matter which ring goes on top/bottom or are they the same?
thanks!
paper head gasket :*:
Maybe that is one of those 65mph parts :crazy:
are you sure that there are not two base gaskets :wink:
B-Nasty
Post by B-Nasty »
spree motor is up and running.
B-Nasty wrote:spree motor is up and running.
not with a paper head gasket i hope :surprise:
niftyman
Post by niftyman »
I hope u dont think that the 44 kit is gonna get you to 65
DJ1
NEK MINNIT
Malossi
DJ1 54mph
dio gear swap in progress
living in chch NZ
earthquake central
B-Nasty
Post by B-Nasty »
haha ya the 44 kit wont come close to 65 but it will get me to about 30......yall will see soon what happens from then on
niftyman
Post by niftyman »
If you hav fitted the bbk why havent you started the build thread
DJ1
NEK MINNIT
Malossi
DJ1 54mph
living in chch NZ
earthquake central
niftyman wrote:If you hav fitted the bbk why havent you started the build thread
Because a 44 BBK is not worthy anymore of a build thread, post *. Especially without a gear change and an intake kit.
B-Nasty
Post by B-Nasty »
pretty much...once I make my build thread you will see why the 44 bbk is insignificant. I plan to make some headway on it tonight so maybe I will have some pics up tom or the next day
B-Nasty wrote:haha ya the 44 kit wont come close to 65 but it will get me to about 30......yall will see soon what happens from then on
...you will have to long and hard for anybody who gives a sh*t....
B-Nasty
Post by B-Nasty »
you accidentally the whole thing
