tire change
bluebullitt2003
tire change
Post by bluebullitt2003 »
ok so.....im a NOOB at this scooter stuff. give me a car and ill do just fine, but how in the world do you take of the rear tire on an 85' spree. I got the front tire off in about 3 minutes, but the rear......what the *. I whaled on that rear bolt and almost started to strip it so i stopped.....dont want to pay out rageous prices at a shotp to that the tire taken off.
any ideas or is there something im missing?
85' Spree
2005 Civic SI VBP
1969 Cougar Eliminator Clone
Mystic
Re: tire change
Post by Mystic »
spray it with some multilube or at least some motor oil, place a stick through the rim so that it braces against the engine, put your socket wrench on the nut and get a longer pipe for leverage to try that. do you have an impact wrench?
killerpancake
Re: tire change
Post by killerpancake »
i've dealt with some so stuck i had to use an impact And spray lube. I'm sure you're not doing it wrong, they can just get very very stuck.
(Previous)
87 honda spree
85 honda spree
(Current)
88 yammy razz
(parts bike)
another 88 yammy razz
bluebullitt2003
Re: tire change
ok thats what i though. i dont have an impact wrench, and i dont really have any place to put it on a jackstand, so i guess ill get a long * wrench to get that bolt off. Ill hit up autozone tonight and get some penetrating oil, see if we can get that thing loosened up
85' Spree
2005 Civic SI VBP
SuprasNsprees
Re: tire change
Post by SuprasNsprees »
mine came right off , with a short-handled half inch wratchet .
I locked the rear brake, sat both wheels on the ground, got it off all by myself
maybe hit it with some PBblast, if it looks rusty
'80 Puch Magnum MKII
'78 PA50 Hobbit
Mystic
Re: tire change
Post by Mystic »
you can do what SuprasnSprees suggests and tap the handle of the socket wrench with a hammer to break it loose, put a little motor oil behind the nut for good measure :D
bluebullitt2003
Re: tire change
how about i just shoot it lol
85' Spree
2005 Civic SI VBP
killerpancake
Re: tire change
OR... weld it so it never comes off, and sell it. see how * they get. :bowrofl:
(Previous)
87 honda spree
85 honda spree
(Current)
88 yammy razz
(parts bike)
SuprasNsprees
Re: tire change
i bet you can change that rear tire , with the wheel still on it :naughty:
'78 PA50 Hobbit
Spree<3
Re: tire change
Post by Spree<3 »
Mine was stuck too. Tried all the above suggestions (other than shooting it or welding/selling :smile: ) and ended up having to cut it off. I have an impact driver... all that did was strip the nut. Good luck :smile:
1986 Spree
bluebullitt2003
Re: tire change
d***, i hope i dont have to cut it off, that would really chafe my * lol
85' Spree
2005 Civic SI VBP
SuprasNsprees
Re: tire change
bluebullitt2003 wrote:d***, i hope i dont have to cut it off, that would really chafe my * lol
using a 19mm socket , correct ?
'78 PA50 Hobbit
bluebullitt2003
Re: tire change
i was using a 17mm socket, that is the one that fit the current bolt on it
85' Spree
2005 Civic SI VBP
Re: tire change
When you put the axle nut back on, put a little muscle on it too. Torque is 47-58 ft/lbs. Peak reading matches the torque of a Geo Metro engine :D
martynkim
Re: tire change
Post by martynkim »
6 foot fence post on a ratchet and a friend to keep it on the nut. :smile: Good Luck I use an impact. :surprise:
