Page 1 of 2
87 honda elite running problem
Posted: Mon Sep 26, 2011 5:46 pm
by error1exe
i have gas coming from a hose under the muffler and not sure whats causing the problem. Also its having trouble stay running. if some one can narrow the options down i would appreciate it. i kno it might be the needle or petcock might be the problem of it not running proper?
Re: 87 honda elite running problem
Posted: Mon Sep 26, 2011 5:50 pm
by swimmingfree
the float is stuck or the petcock is stunk open pull the hose and see if gas is running out it shooed not
if no clean the carb
Posted: Mon Sep 26, 2011 5:54 pm
by error1exe
swimmingfree wrote:the float is stuck or the petcock is stunk open pull the hose and see if gas is running out it shooed not
ok thnks ill give a try
Posted: Mon Sep 26, 2011 5:55 pm
by error1exe
thnks ill give it a try
Posted: Mon Sep 26, 2011 6:02 pm
by swimmingfree
did you pull the hose if so what happen ???
Posted: Mon Sep 26, 2011 6:15 pm
by error1exe
theres a black hose a red one i pulled the black n nothing was coming out
Posted: Mon Sep 26, 2011 6:17 pm
by swimmingfree
is the gas still comming out ??
by error1exe
swimmingfree wrote:did you pull the hose if so what happen ???
not sure if a i gota quote or reply but pulled black hose no gas was coming thru
Posted: Mon Sep 26, 2011 6:19 pm
by swimmingfree
is the gas still comming out of the carb???
red black means nothing to me
Posted: Mon Sep 26, 2011 6:20 pm
by error1exe
nope no gas was coming from the black hose, black hose was connevted to the bottom of the petcock, the red hose is connnected to the top. should i pull the red one?
Posted: Mon Sep 26, 2011 6:22 pm
by swimmingfree
is the gas still comming out of the bottom of the carb???
Posted: Mon Sep 26, 2011 6:23 pm
by error1exe
im new to this i work on my cars n thats it lol i just got this spree n no nothing bout it. but i also work on small engines so i kno how to manage a carb if need be.
Posted: Mon Sep 26, 2011 6:29 pm
by swimmingfree
here some on cleaning the carb
http://www.hondaspree.net/phpBB3/viewto ... f=5&t=8786
Posted: Mon Sep 26, 2011 6:37 pm
by error1exe
is the hose thats leaking gas connected to the carb? if yes then it is still leaking when its running or im trying to start it
Posted: Mon Sep 26, 2011 6:42 pm
by swimmingfree
then dont try to start it .. clean the carb the float is stuck
