My First Spree Swap (Aero NH125)
Tyler VR
Post by Tyler VR »
Hello everyone, :coolcruise:
I'm new here but have been lurking this great and resourceful forum a couple months now. All the info has helped me bring my first spree back from the dead. But the stock NQ50 doesn't cut it on a lot of the roads here, but very fun to ride. I guess the usual complaints apply, just not fast enough and sucks on hills.
I figured a swap would be my best option to go the speeds I wanted, so I hit the classifieds for a donor moped. I was lucky enough to score a 1984 Aero 125 for only $150, but it hadn't ran in years. With a bit of effort and reading the manuals available here on the forum I got it fired up, but still needs some carb parts to run right.
It would be a shame to take apart my first spree for this swap, so I found another frame to mangle. I fabricated a motor mount so far, lining everything up was pretty difficult. Did a quick shock mount, but planning to redo it and use 2 shocks like the Aero. Also thinking about re-enforcing the frame a bit.
NH125
donor aero next to my first spree
Motor mount:
Test fitting the fairings
Mystic
Re: My First Spree Swap (Aero NH125)
Post by Mystic »
WOW looks super kewl so far man, great job :thumbsup: once you get the motor good and mounted you should look into swapping the front forks from the aero to give you the added stopping powers and it would raise the front end to match the rear :D
Post by swimmingfree »
boy for a first build looks Grate !!
glad to have you post and come out on here ...
hay ill bet some one on here wood like to buy your spar body parts
Tyler VR
Post by Tyler VR »
Mystic wrote:WOW looks super kewl so far man, great job :thumbsup: once you get the motor good and mounted you should look into swapping the front forks from the aero to give you the added stopping powers and it would raise the front end to match the rear :D
Thanks, I've been thinking of a front brake swap but the 125 is too big. I'd like to get a hold of an aero or elite 50 front setup.
Tyler VR
Post by Tyler VR »
swimmingfree wrote:boy for a first build looks Grate !!
Thanks! The aero body parts will be up for sale soon, probably cheap too. Also have the bare aero frame w/title, so I'll try to sell that too.
Mystic
Post by Mystic »
you sure you cant take the entire front fork loose, cut the stem off and weld the stem from the spree onto the aero forks? thats what I did with the elite sa50 fork and the spree stem, you have to modify the plastics then again I have no experience with the aero 125
Tyler VR
Post by Tyler VR »
After pulling the aero front fork assembly off the frame and comparing it to a spree fork I think it might be do-able. Probably won't get to it until this winter.
Mystic
Post by Mystic »
Yup I think you can do it and it would be alot safer :D
sum-azn-kid
Post by sum-azn-kid »
why not disk brake your spree?
zuma 125-sold
Ninja 250r-totaled
i will say something about the front end swoop better ride braking and look ...
with that motor if you don't put a speed o meter
((lol lol ))
you may end up with a fue speeding ticked so you may want to think about that
Tyler VR
Post by Tyler VR »
sum-azn-kid wrote:why not disk brake your spree?
I haven't researched this yet, what model scooter can you swap disc brakes from? I think it would be hard to find a complete setup, might as well just use what I already have and save money.
Tyler VR
Post by Tyler VR »
swimmingfree wrote:i will say something about the front end swoop better ride braking and look ...
((lol lol ))
Yeah, my brakes suck on my stock spree so I could imagine trying to stop going even faster. I can't get caught doing over 35mph here without a motorcycle endorcement, so I'll have a speedo for sure.
Tyler VR
Post by Tyler VR »
Did some re-enforcement work on the frame and new shock mounts.
Tyler VR
Post by Tyler VR »
Got the engine back on and wired up, I'm using the complete aero wiring harness spliced into the spree cluster and left side hand controls. Still need to finish up a couple things, the foot brake safety switch needs to be bypassed and run wiring to the hand brake.
bradthreee
Post by bradthreee »
Great Work Tyler!
If you need some disc brake info hit me up!
:thumbsup:
