I have started replacing the clutch and breaks on my 85 spree. I have the clutch off the drive plate (page 8-10). my question is should I give the clutch pivot pins a light coat of machine oil before I replace the clutch shoes?
Also when I removed the crankcase cover it had no gasket. Should I get some gasket material and replace it?
Jerry
replacing clutch
- Shootin_Spree
Yes, oil and clean the pins.
No, do not use make-a-gasket (ever.) Either buy a new one or run without. I bought a new one since mine was missing and found that
1) it gets in the way
2) doesn't seem to help anything.
- Shootin_Spree
- Shootin_Spree
It's done
I replaced the clutch, belt and starter pinion. All seems to work well.
Thank you all for your advice.
