I'd like to get a complete motor that I can disassemble, clean up, reassemble to understand how it works. Reading manuals is good but I learn better hands on.
What actually happens when they say motor is "seized"? Can the motor be rebuilt and be used again? if I found a bike on CL or a garbage sale, how do you know if it's seized when the bike doesn't run?
I never can find the great deals you all talk about. Just want a junk bike to learn. Doesn't need the plastics, seat etc. Anyone got some ideas or a motor to help a beginner in grand rapids mi?
Want to learn how the scoot works.
terryc8171
- Goped
'87 SE50
'87 NQ50
'87 NQ50
- swimmingfree
Re: Want to learn how the scoot works.
what are you looking for spree elite ?? best not to say whatever .. if your going to take the time to fix it ..
yes most of the time if you got anuff money they all can be fix but is it worth it
just kick it dose not move seized the piston rusted to the walls or piston broke up and jam in the crank or ???terryc8171 wrote:What actually happens when they say motor is "seized"? Can the motor be rebuilt and be used again? if I found a bike on CL or a garbage sale, how do you know if it's seized when the bike doesn't run?
terryc8171
- Goped
Thought elite so it's like my scoot. If I get the basics, then I should be able to understand other motors.
'87 SE50
'87 NQ50
'87 NQ50
No, that means something is locked up. It could be the kick start, not the motor. The only way to tell if a new-to-you bike is seized it to actually pull apart the engine. Sometimes the crank bearings are locked up and the top end is fine.swimmingfree wrote:just kick it dose not move seized the piston rusted to the walls or piston broke up and jam in the crank or ???terryc8171 wrote:What actually happens when they say motor is "seized"? Can the motor be rebuilt and be used again? if I found a bike on CL or a garbage sale, how do you know if it's seized when the bike doesn't run?
