Fall Project Black
Smile
Fall Project Black
Post by Smile »
I just thought Id document and share this fall project of mine "Black"
(DIO Converted Honda Smile)
Started of with a blank canvas, a JDM Honda Smile frame (Japan version of the honda spree) and a wrecked Aero50 frame.
Chopped off the smiles motor mount box and also chopped off the aero50 motor mount box then welded the aero50 motor mount box to the smile frame. Reason why I did this? The aero50 motor mount box is much more sturdy than the smile/spree and most importantly to have a center stand.
I robbed the shock mount bolt off the aero50 the relocated and welded it to the spree frame.
Took the aero50 motor mount, cut the tongue out, flipped over the mount, then shortened the mount and relocating the bottom pipe of the mount to the left then welded the tongue and bottom pipe. I shortened the mount so that motor will clear the rear fender by 1/4 inch and ped will have a lowered stance to it.
Ive decided to make this a beast of a ped...55mm bore x 52.6mm stroke, did a test fit and noticed pipe hitting the frame so I cut a notch in the frame then welded a piece of pipe from the aero50 frame then I reinforced that side of the frame with some mild steel.
Just spraypainted all the areas on the frame that was welded, Finished most of the major engine work and slapped it into the frame.
Cleaned up the ol Bull Pipe, used krylon bbq black spray paint then torched it. Wrapped the header with some exaust wrap, did this because pipe is very close to the plastics, will also put some insulating cool tape on the back side of the plastics thats near the exhaust.
Re: Fall Project Black
Post by swimmingfree »
looking good nice photo
im along for the ride on this build
tazland001
Post by tazland001 »
Looks good so far.
Taz
sum-azn-kid
Post by sum-azn-kid »
nice build. man sprees look like a pain to convert to dio compared to the elite E good luck on your project
zuma 125-sold
Ninja 250r-totaled
Smile
Post by Smile »
did lots this week, motors in
looking good !!!
you may want to have some one sit on it the cut out for the ex pipe may hit the pipe ..
Smile
Post by Smile »
tazland001 wrote:Looks good so far.
Taz
Thanks Taz
sum-azn-kid wrote:nice build. man sprees look like a pain to convert to dio compared to the elite E good luck on your project
yeah it was a pain but it was well worth it, I can now utilize the centerstand and not use a brick when doing engine work
swimmingfree wrote:looking good !!!
Great Tip, Im thinking of customizing the pipe, I really dont want to cut any panels.
Smile
Post by Smile »
been very busy lately and havent had the chance to sit and enjoy this project till now.
threw on the front end, lowered the forks a bit
Finished up the engine work
Used thermal tape to protect plastics that are dangerously close to the headers, hope plastics dont melt
getting all the accessories ready, very rare sidestand and oem rubber floorboard mat
...a most impressive custom, and you have preserved much of the Smile outward character, at least so far.....the dio is suuuuweeettt...nice detailing...black is perfect for this sleeper, red wheels the cherry on top....like the brake hub red, looks flawless.....
kingkamehameha
Post by kingkamehameha »
I like the sidestand. I've got the same one
Smile
Post by Smile »
motormike wrote:...a most impressive custom, and you have preserved much of the Smile outward character, at least so far.....the dio is suuuuweeettt...nice detailing...black is perfect for this sleeper, red wheels the cherry on top....like the brake hub red, looks flawless.....
Thanks motormike, yes it was my intent to keep it looking stock, I dont like cutting panels and i dont like the rear tires touching the rear mudflap like other dio spree hybrids. trying to make it a sleeper but this 125cc motor with scorpion pipe is not helping it out lol
Smile
Post by Smile »
some other pics below, getting close to completion
getting closer
kingkamehameha
Is that the same side stand as the elite one? Or is the mounting bracket different?
e-Pirate
Post by e-Pirate »
I'm loving this bike :D
SWAG
1984 Honda Spree
1985 Honda Gyro S
1977 Honda Camino
1960 Alpa Moor
2009 Piaggio MP3 400
2002 BMW 330xi
Smile
Post by Smile »
kingkamehameha wrote:Is that the same side stand as the elite one? Or is the mounting bracket different?
Nope different one this sidestand is specifically made for the smile, bolts on the floorboard rail. very similar to the honda pal sidestand but shorter
