Aero 50 rear turn signal lights being weird after spark
LocoParaHonda
Post by LocoParaHonda »
I recently had my scooter stolen and recovered with a chiseled out ignition. :evil: I ordered a new ignition from an ebay guy in the UK, but while I'm waiting, I hotwired the red and black wires to make it functional. (with a U-lock through the front tire/mount when it's parked!)
Anyways when I was fiddling with the wires they brushed up against the frame of the bike and made a small spark. After this small spark, the rear turn signals won't work right.
The brake light lights up, but when I put on the turn signal, the brake light goes out and the turn signal I selected lights up steady on/non flashing. The headlight works fine.
Any idea what I might have done or how to fix it? thanks.
85 Honda Aero 50 w/kickstart and Keli variator. (Proteus)
86 Honda Aero 50
87 Elite 50-S parts ped
bonesv
Re: Aero 50 rear turn signal lights being weird after spark
Post by bonesv »
LPH, do you have a known working turn signal flasher you could replace yours with, maybe from another scooter? I believe the dash and headlights work off of the alternator. Everything else I believe runs off of the battery. Maybe Bear can help you with this. Good Luck to you. Happy Trails!
turtle13
Post by turtle13 »
i had a very similar situation with my aero when the flasher relay went out. a trip to the auto parts store and about 5 minutes and it was fixed.
'62 125cc Honda cub
I agree with the flasher being fried.
LocoParaHonda
Turns out it was the fuse. I replaced it with the fuse from my parts moped and everything's hunky dorey again.
The parts ped fuse is a 10 AMP and the one I took out was a 7 AMP. Will that cause problems if I leave it in there?
Sorry to double post if anyone got the other one I posted on another thread.
86 Honda Aero 50
