POLINI CONTESSA 72CC WITH A STOCK SYM BLOCK.
Posted: Wed Oct 19, 2011 6:54 pm
by 96706EliteS
MY OLD SET UP WAS A 72CC POLINI CONTESSA WITH A STOCK SYM BLOCK. IT SEEMS LIKE IT WAS RUNNING ALOT BETTER WITH RUNNING THE POLINI BLOCK WITH THE POLINI BORE... DOES ANYONE KNOW ANYBODY THAT EVER USE THIS SET UP... I WOULD LIKE TO KNOW MORE ABOUT IT, AND THINKING ABOUT PORT MY STOCK SYM BLOCK JUS A LITTLE.
THANX!
Re: POLINI CONTESSA 72CC WITH STOCK SYM HEAD
Posted: Wed Oct 19, 2011 7:12 pm
by bonesv
I think you should learn to have some patience first, and then maybe someone would help you. You just posted this same thread 6 minutes ago! Get a hold of yourself man.
Posted: Wed Oct 19, 2011 7:17 pm
by 96706EliteS
MY BAD BRO!
NEW TO THIS SITE AND DON'T REALLY KNOW HOW TO USE IT... I JUST WANTED TO MAKE SURE THAT IT GETS OUT THERE... LOL
Re: POLINI CONTESSA 72CC WITH STOCK SYM BLOCK
Posted: Thu Oct 20, 2011 4:46 am
by veedubh20
Lol! I charge arm n legs porting...
Posted: Thu Oct 20, 2011 9:40 am
by noiseguy
Gawd.
1) Knock it off with the double and triple posting. Wait a day before bumping a topic.
2) Knock it off with the all caps. See that button with "Caps Lock" on it? Push it.
Posted: Thu Oct 20, 2011 3:26 pm
by 96706EliteS
I just wanted to know if my old setup is better than my new one... I thought that going to this site would help me out, but i guess i was wrong bout' that... Ama have to look at another site and hope that someone would take me under their wing and help me out...
thanx' anyway!
Posted: Thu Oct 20, 2011 4:31 pm
I just don't see too many Spree Forumistas reporting direct SYM experience. I do realize that SYM engines were clones of Honda's design, so the same rules should apply, but maybe not.
You'd think the normally well-engineered Polini kit would work best with a Polini-matched cylinder head, but possibly not for some reason on your application. I suggest you perform compression checks using the SYM, then the Polini head and report your findings. I know my Corsa has good performance despite a relatively modest CR.
Posted: Thu Oct 20, 2011 7:43 pm
by kingkamehameha
sym blocks have tiny intake and boost ports. Those should be done by someone who knows what their doing. Polini kits need the polini heads I you want the compression to be right.
Posted: Fri Oct 21, 2011 4:54 am
by 96706EliteS
right on bro! thanx to all you guys who try helpin' out new peeps... i don't know much, but i', willing to share what i know... ama try your advices and see what i come up with... one more thing, i came up with another problem i put on my new polini kit and it started jus fine. i rode it 15 to 20 mph, but when i tried to gas it more it starts to bog and the exhaust sounds different, but it doesn't die out. when i release the throttle it rides jus fine. what's wrong with it?
appreciate any help....
Posted: Fri Oct 21, 2011 9:15 am
EliteS Axt:
I'm tempted to say it's the
throttle grip. It's being turned by a feller who's not very good at outlining an issue or finishing a thought. But I won't say that.
To get help with this question, you would need to give us just a bit more 411 on your setup. What pipe, carb, jet size, air filter, etc.? Did you measure compression?
Posted: Tue Oct 25, 2011 3:11 pm
by sum-azn-kid
i had a 72cc corsa on a stock block sym. nothing wrong with it. i could keep up and pass honda block 72s and 86s. just tune it.
Posted: Wed Oct 26, 2011 4:46 pm
by kingkamehameha
Sum-azn-kid the sym boost port is much smaller than the elite port and so is the intake port. It will run with a stock block but your not gonna reach the true potential and tuning is harder. The boostt port needs to be matched
