Honda Dio AF-18 90cc 90Km/h
Vidra
Post by Vidra »
Honda dio AF-18E engine cylinder 50mm Ruima carburetor Dellorto PHBHB 28mm main200 exhaust 28mm v8 Crank 44.0mm Clutch Spring red Clutch Pad Springs white Primarygear Malossi16/32Secondargear Ruima17/42 Malossi KEVLAR Belt Pulley 8g Air Filter X2
tazland001
Re: Honda Dio AF-18 90cc 90Km/h
Post by tazland001 »
I like it. Where are the rest of the panels?
I have seen a lot of AF18 builds similiar to this in the Philippine websites. The AF18 is still my fav out of all Dio models.
The side panels look like the zx dio??
Taz
sanjuro
Post by sanjuro »
Just a point of clarification, that is an af27 Dio with an af18-e motor. Early dio af18 or af25 generation scoots shared the af18-e motor with the subsequent af27 and af28 super Dio version. The 2nd gen dios used a bigger crank and had different oil seals for the crank.
Af28 scoots were usually found with the yellow headlight and disc brakes with rear wing. Alot of people would upgrade the wheels and disc brakes even though they started out as af27 bikes. The wiring harness and cdi are slightly different between the af27 and af28.
I would suspect that gears are need to make it really go fast.
tazland001
Yah I kinda figured. I couldnt tell on the front but the rear was obviosly not a AF18 Dio. The front also gives it away with the disk brakes. The AF18 came with drum.
Taz
Munstah666
Post by Munstah666 »
tazland001 wrote:Yah I kinda figured. I couldnt tell on the front but the rear was obviosly not a AF18 Dio. The front also gives it away with the disk brakes. The AF18 came with drum.
Taz
There is a disked af18 --- it is the af25 Dio SR (all it is an af18 with disk brakes) ... sanjuro is right, hard to tell if that's an af27 or 28 maybe a converted af27 to af28?. Can tell if the stock speedometer is there. But definitely a Super Dio (2nd gen Dio). I dunno but that bike looked pretty butchered and the "honda" logo in the seat aint oem.
µùѵ£¼Òü«Òé╣Òâ╝ÒâæÒâ╝Òâ×Òâ│
Vidra
Post by Vidra »
Hi all You're right it is a body AF27, the AF-18e engine, front wheel fork brake AF-36.
808BMW
Post by 808BMW »
More pics of the red bike next to it ;)
Vidra
Post by Vidra »
Hi all
Red bike Honda DJ-1 Frame
Honda Vision 70cc cylinder engine Mollossi delloto 17.5 carb.
Not yet ready for top speed 95KM / h
Pictures soon
Vidra
Post by Vidra »
Hi all red bike last year's photos.
808BMW
Post by 808BMW »
I knew it was an 87, I was hoping it would be a DJ-1... any interest in selling+shipping the headlight+plastic?
Vidra
Post by Vidra »
Sorry I do not understand.
Tell me more.
thank you
