Variator questions
Posted: Sun Oct 30, 2011 11:29 pm
by TiffanySpree
I made Sharpie marks on my variator, which is stock. The only mod i made to the transmission other than the 9:1 gears is a 1500 rpm center spring. After a ride with revs up to 7000 rpm, I checked the variator marks and found that the belt (5O miles on new oem) does not ride near the edge. It is about 10mm or so short. Is the heavier center spring preventing this? I have oem 10g rollers that are not flat spotted. At what rpm should I expect the tranny to fully upshift? In my previous stock af05, it was about 5000 rpm. Shouldn't this one upshift about 6500 rpm? My understanding is that the sa50 and se50 belts are the same, although the part numbers on my two belts are different. Se50: 23100-gz5-0130. Sa50: 23100-gg2-7500.
Re: Variator questions
Posted: Thu Nov 03, 2011 4:31 am
by maddog
dump the stock variator for a hi-speed one, use 8.5 gr.weights, use a washer between the boss & ramp this will bottom out the belt letting it ride the entire pulley, change the clutch springs to polini greens if you hit 53mph you are there :smile:
Posted: Thu Nov 03, 2011 7:25 am
by TiffanySpree
Ok, I'll shop for a variator. Now, will a Ruckus variator fit without grinding? Also, if I get a bigger variator, is the belt long enough? If the belt is long enough to hit the extreme ends on the stock front and rear pulleys, it seems it won't be long enough for a bigger front pulley. Unless, it does not go all the way down on the rear with a stock variator.
For now, I'll try the washer idea along with lighter weights. I have three 8 gm rollers I can try with three stock ones. The next size down in my kit are 6 gm rollers. What size washer should I get? ID and thickness?
Posted: Thu Nov 03, 2011 11:12 am
TiffanySpree wrote:Ok, I'll shop for a variator. Now, will a Ruckus variator fit without grinding? Also, if I get a bigger variator, is the belt long enough? If the belt is long enough to hit the extreme ends on the stock front and rear pulleys, it seems it won't be long enough for a bigger front pulley. Unless, it does not go all the way down on the rear with a stock variator.
Rule one is never do what maddog, AKA * puppy, says to do, ever. First off each scooter and engine is an individual and at best a variator setup is a guess. Just do the weight thing, skip the washer.
Posted: Thu Nov 03, 2011 12:21 pm
by TiffanySpree
Hmm, ok, I'll keep that in mind. I guess I haven't been here long enough to notice.
Anyway, since I'm still in the break-in period, I'll just leave it alone. I had the lighter weights before I notice the variator not fully extending. That's why I put back the heavier OEM weights, thinking it will push out more for the same RPM. I don't want to push the motor right now just to see where it will max the variator. I'll wait until next spring. I doubt I'll break it in before winter comes. So while I'm breaking it in, it is all stock except for the 1500 rpm c-spring and lighter clutch bell.
Posted: Thu Nov 10, 2011 2:54 am
by maddog
ha ha, i will let the local boyz make the bear look like a piece of s*** on this one, they also sell shims contact vt cycles, thats why "whinnie the poo" can't go 103mph on his sorry * aeros like i can :bowrofl:
Posted: Fri Nov 25, 2011 8:09 pm
by maddog
if your running stock you need to do all the derestrictions which the bear has no clue about :crazy:
Posted: Fri Nov 25, 2011 9:49 pm
by odinxxix
:*: * puppy really? i think somebody yanked on your yard chain and you are making up as you go along, im noe expert but i dont think you could get enough rpm to go that fast. we dont believe unless we see proof. * we havent seen these machines of yours. :jack: :roll:
Posted: Fri Nov 25, 2011 10:32 pm
* head never shows proof of anything. Never shown a pic of a supposed scooter much less a time slip or a GPS readout. He lies more than obozo does.
Posted: Sat Nov 26, 2011 5:58 am
by atomicareprise
u have a high expectation over a stock engine bro....
running a 1.5k rpm on a stock engine is a little bit off...
1.5k rpm is too stiff for an engine of urs...
try using a 1k rpm clutch spring then a stock center spring...
try to observe when does ur rpm drops..
if it drops in the middle try to use lighter rollers...
