2012 Moped Race Classes
kryptonite
Post by kryptonite »
DRAG RACING classes for the 2012 season
limited to honda style motor for classes 100, 200, & 300: nq50, af05, af16, af18
All Classes - any use of demel or any handy tools used for smoothin, grindin, sanding, polishing of the intakes/block/exaust is acceptable :)
100 class: 50cc ONLY
250lbs weight minimum with rider
Pure stock 50cc ( factory bore and crank must be used)
2 stroke or 4 stroke
Any variator/rollers/springs combinations allowed
NO aftermarket cranks (stock elite S)
Any exhaust
Frame is "stock" and of unmodified material (engine extensions are allowed)
CT style manifolds are allowed
Carb limit to 28mm
Gear Combo limit to 9.8
No NOS
200 class: 51cc to 90cc ish
275lbs weight minimum with rider
Any "bolt on and go jug"
No polini/malossi jugs
Factory stock crank only!
Carb limit to 30mm
Any frame mods
No NOS
300 class: - 72cc to 95cc
300lbs weight minimum with rider
Any carb & manifold
Any variator/rollers/springs combinations Allowed
Polini/Malossi jugs are allowed
Mini stroke cranks are allowed
Any frame mods
No NOS
400 class: - 100cc to 130cc
Any non Honda engine is ok
Limited to "1" cylinder engine
Times will be separated with NOS/ No NOS
1/8 mile is the standard for posting times, if one makes a 1/4 mile run.. Since they are so few of them will be lumped in to there own catagory for now :)
Multiple mopeds per class is ok
These classes are a start, when makin a post, pleasse use this format
Forum Name - Class - Time - Dist - Date - Frame
when of if there is enough postings we will condense to a top 10 per class
Happy Racing !!
fastplastic
Re: 2012 Moped Race Classes
Post by fastplastic »
:hi:
ottoman
Post by ottoman »
Darn eliminated by the rules before we could even race with you guys :(
Well we do have a Honda front end and a 86cc motor... if I put a honda sticker on can we race?
lol... looks nice, hope you get some guys interested!
kryptonite
Hey Jim! !!
You are in luck!! You would be in the 400 class, its primary Honda classes but the 400 class is open to "any engine" :) :)
-Ben
tru72
Post by tru72 »
LOL ben and I went thru alot of conversations trying to get it as even as possible. Im guessing the times with the weight limits should get some super close times! Its all on the honor system here. I went thru every combination and used my experience to make sure that things would all come down to tuning it for the most performance. These are general rules and will and can be changed at any time when different options pop up.. This is just some guidelines to get people into tuning and racing their bikes no matter if its stock or modified!
pm me or krypto if anything.
Aloha
D
ottoman
Post by ottoman »
Oh yea... 400 class.. soo I can run a hyabusa with nos in this class since it weighs more than 300lbs? :ndance:
400 class: - 100cc+
Any non Honda is ok
really no limits
ottoman wrote:Oh yea... 400 class.. soo I can run a hyabusa with nos in this class since it weighs more than 300lbs? :ndance:
400 class: - 100cc+
Any non Honda is ok
really no limits
Maybe we should put a 150cc, or single cylinder limit on this class. :wink:
tru72
Post by tru72 »
LOL @ Ottoman - figures you would post something like that haha!
FI- no radiator/pump yet, ordering one from scootercraft on monday, cant wait for that other one to show. If it does i got a spare
Traffic - Good idea on being more specific on that.
ottoman
Post by ottoman »
Better to get the bugs out of the rules before racing starts :thumbwink:
..............I wanna play................... :cry:
gyro 4.jpg (12.26 KiB) Viewed 30854 times
gyro 3.jpg (28 KiB) Viewed 30854 times
gyro 1.jpg (46.45 KiB) Viewed 30854 times
kryptonite
Hey MotorMike
whatcha got to race with? Im sure we could make it fit some class :)
-Ben
........as the pix indicate, '85 Gyro S-50cc stock, '86 Elite 80(still in street trim), and a '74 XL 100 Honda eligible for motard conversion.....the Elite 80 has no title, so track-scoot material definitely.
fastplastic
Does 1/8th mile drag racing only show up in ur rules at all Ben?
kryptonite
Well i wasnt limiting it to just that, but since thats the only track we run on iguess thats all we got, if we have the chance to run 1/4 mile than yea in the future we could have just a top 10 for that distance no matter what engine you have
im just thinking most people would be glad just to run down a dragstrip with their mopeds and not have safty rules a mile high or many many hoops to jump thru just to find out how they compair to others
hope this helps
-Ben
............oh,...drag.......racing :surprise:
