honda dio simonini performance
scottinscotty
Post by scottinscotty »
Any word on these pipes? Recomended Bore Sizes? Rpm Range? Good? Bad?
72cc polini contesa kit
oko variator with 8.5 gram malossi weights
21mm Black Oko Carb & Ct Manifold
8.44 gear
malossi MHR exhaust
Dio zx trans conversion
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
scottinscotty
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
jlynn433
Re: honda dio simonini performance
Post by jlynn433 »
scottinscotty wrote:Any word on these pipes? Recomended Bore Sizes? Rpm Range? Good? Bad?
heard of em a few different times, havent actually heard any good or bad on em... i guess if you can find a tried and true build that has one id give it a shot
'00 Honda Elite S.....................'06 Yamaha Zuma
-80cc Taiwanese BBK...............-Taiwan pwr pkg
-Malossi Vari
-6.9:1 Primary gears
-High Energy Ignition Coil
-Carbon Fiber Reeds
-Chrome CT Mani
-28mm OKO Carb
-Uni Pod Filter
-PG Long pipe
z50r-ghost
Post by z50r-ghost »
... I saw those on treatland as well.
Simonini quality is great, and as far as their moped pipes go; they are great performers. As for their scooter pipes...? Im sure that they would be good performers as well... Simonini has been around forever and I've never heard a bad thing about them in moped world. Hope this helps! -it *looks* like a really sweet chamber... Hmmm...
>< Solitaire Unraveling ><
...my life story
1990HONDANS50F
Red Eft Performance
Post by Red Eft Performance »
I talked to Simonini some time ago and the only info they had on the pipes were that they were 72cc. I dont know anyone that has run one but I assume these pipes would work great on a corsa or MHR.
Red Eft Performance
View products click => Here
