45mm bore
Pierce ramsay
45mm bore
Post by Pierce ramsay »
45mm bore, 24mm oko carb, v8 exhaust .... Carb jet suggestions?? Thanks for the much needed help getting me in the ball park would be great!
bakaracer
Re: 45mm bore
Post by bakaracer »
Pierce ramsay wrote:45mm bore, 24mm oko carb, v8 exhaust .... Carb jet suggestions?? Thanks for the much needed help getting me in the ball park would be great!
48 pilot 118 main
Pierce ramsay
Re: 45mm bore
Thanks!!! Haven't been out to change'em yet but as long as she runs I can tune her from there!
Pierce ramsay
Re: 45mm bore
Put a 48/120 in no 118 do have a 115 tho. It's about 50 degrees here running a brh8s plug. And I am only about 170feet above sea level. I know these conditions will Change the jetting. Couldent see to get her started with the 48/120 think I might try the 48/115 combo. Thanks
Pierce ramsay
Re: 45mm bore
Also will the stock head fit well for compression or is a 51mm head better I don't have a 45mm is that a must or will it run with one of the two above?
Mystic
Re: 45mm bore
Post by Mystic »
it will run with the stock head as long as the piston doesnt touch it at TDC but I had mine milled to match and the squish done too
Pierce ramsay
Re: 45mm bore
Mystic wrote:it will run with the stock head as long as the piston doesnt touch it at TDC but I had mine milled to match and the squish done too
Is this better than using a 51mm head?
Mystic
Re: 45mm bore
Post by Mystic »
yea i would think so
Pierce ramsay
Re: 45mm bore
awesome, thanks for the info i will swap them tomorrow morning, altho she was running poorly with the 51mm head on but if she will run better with the stock head on im all for it! i have 2 stock head so i will put one on and take the other one to the machine shop. any other thoughts on jets still cant get her to start agian? have tryed 48/120 48/115 and 48/110. should i try a 45/115?
Mystic
Re: 45mm bore
Post by Mystic »
change the head then see if it starts
Pierce ramsay
Re: 45mm bore
headed to my man cave right now to go try it :) post afterward
Mystic
Re: 45mm bore
Post by Mystic »
before you start it make sure the piston doesnt hit the head, might have to add an extra headgasket for clearance not sure
Pierce ramsay
Re: 45mm bore
just swapped and tested proud of my 35min head swap :)..... not proud of my non working sexy beast (yes thats her name) so a 45mm bore and a stock 39mm head. jets at 45/110 and not starting, sounds a little on the rich side kinda boggy sounding when trying to start... any other suggestions, new head gastket with swap and new plug.
Pierce ramsay
Re: 45mm bore
Mystic wrote:before you start it make sure the piston doesnt hit the head, might have to add an extra headgasket for clearance not sure
thank you! i double checked and it clears nicely so i continued....
Mystic
Re: 45mm bore
Post by Mystic »
drop the pilot down to the next smallest size with needle clip in the middle
-also check the compression :P
