CRANKS
PurpleMonsta808
CRANKS
Post by PurpleMonsta808 »
i have a stock sym dd50 crank running a 72 contessa fully ported thinking off going mini stroke
would it help me with speed?
would it be better?
and what brand mini stroke crank is the best?
:peace: :peace:
maddog
Re: CRANKS
Post by maddog »
the sym engine just plain sucks :surprise:
Re: CRANKS
Post by eliteguy50 »
Yes. Better speed and acceleration. How much are you looking to gain.
Wait- are you talking about a new build with ministroker or using the contesss with a ministroke?
PurpleMonsta808
Re: CRANKS
as much as i can? y would it help tho with a mini stroke on it
Re: CRANKS
PurpleMonsta808 wrote:as much as i can? y would it help tho with a mini stroke on it
ank combos with bores and pipes.
Better to go with a proper bore then. More pressure. There are more knowledgeable guys that will chime in later with brands and the optimal no clearance cutting crank-bore combos.
sum-azn-kid
Re: CRANKS
Post by sum-azn-kid »
sym stock crank is fine. you can still smoke mini strokes if you tune it right. mini stroke you are going to have to add base gaskets. the polini bores were designed for stock crank i think they are best with them. or if you have the $$$ mhr full circle stock stroke. btw what gear ratio are you running? and pipe?
zuma 125-sold
Ninja 250r-totaled
tru72
Re: CRANKS
Post by tru72 »
AZn knows the power of a ported polini hehe
PurpleMonsta808
Re: CRANKS
im running 7.1 gears and a pg long pipe
veedubh20
Re: CRANKS
Post by veedubh20 »
Ran Dio pg long on a jog :lol: kitaco 7:1
Re: CRANKS
In hi=performance "There is no replacement for displacement!" This especially applies to small scooter motors.
Re: CRANKS
The polini bore is made with the stock crank in mind.
I am not sure if the extra displacement would be off set by the incorrect port timing of the Ministroke :confused:
eg: It may not rev as high with the longer crank.
sum-azn-kid
Re: CRANKS
have you tried the scorp. pipe? and is this motor on a sym? they are heavy i think about 180 pounds.
i wish i kept that ported 72 corsa motor would been fun on my elite e. about 70 pounds lighter then the sym thats why i got it.
zuma 125-sold
Ninja 250r-totaled
