What is a good pipe for the Polini Contesta?
Have a contesta coming in the mail and I am wondering what is a good pipe that isnt too loud and wont break the bank but still allow optimal venting of heat but also keep the engine from over reving? I am thinking the V8 Typhoon is probably my best bet but I would like some opinions. I just cant see running the exhaust I have (kymco zx exhaust which is practically like an unrestricted af18 dio exhaust) Is there any danger in running the stock exhaust?
Re: What is a good pipe for the Polini Contesta?
there is no danger in running a stock exhaust. if you really want to keep the noise down, put a airbox. the intake noise is really loud.
do they make an airbox that is bolt on for the OKO?
don't know if this will fit your scoot, but will fit the oko.
http://www.mopedsplus.net/index.php?dis ... t_id=29901
OOPs first time i sent image link, didn't hit the right button sorry.
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
arreche air filter
v8 pipe
stock gears
- sum-azn-kid
http://www.ebay.com/itm/PERFORMANCE-AIR ... 3f098bbe7d
if you run the stock side(no mesh) would be super quite but may lose some power.
zuma 125-sold
Ninja 250r-totaled
zuma 125-sold
Ninja 250r-totaled
stay away from that airbox just derestrict the factory one for your setup.
Ignore the doggy, You will not get a decent fit with your OKO to the stock air box.
hhahha I already know Bear, I have never actually heard anything useful from him. Plus I dont have any stock airboxes
for a few bucks more you could have a corsa, ask the bear how to convert the contessa into a corsa= its real easy
- kingkamehameha
Ask wheelman about his pg short. Badass pipe
From my research, the PG long/short requires a larger than 21mm carb and is a high rev pipe. The higher the revs and performance the shorter the lifespan of the motor in general.
I frankly can't tell much difference in performance between the PG Long I had and the Short I'm running now. The Long is poorly crafted and the baffle welds break inside the pipe, in my case within a year. It remains to be seen if the Short is any more durable. I've run 24 mm to 30 OKO carbs and they all seem to like to rev into the Mid-10s with either pipe.
- kingkamehameha
Engines can be rebuilt. You have a quality kit made for high rpms why would you skimp out on the pipe. The v8 pipes are easy to tune but have a poor high end. The pgis a good all round pipe
iRiE S0ULJAH
- BMX
id run a pg long , scorpion , arrow, windjammer all good pipes to hit the high speed wit a fine tuned!
- kingkamehameha
Show us pics of all your rare pipes then slowjah
