Hey guys!
My 84 spree has 2400 miles on it and when i ride it. It' sounds like bearing nose coming from the rear
Anything commonly happening with that many miles. It could be on the clutch. Just all new to me. So I don't want to tear into it with out hearing some opinions.
Nic woods.
Question on my 84 spree
- swimmingfree
Re: Question on my 84 spree
the first thing i wood do is down lowed the manual..
http://www.hondaspree.net/other/Spree_NQ50_84-87_1.pdf
Lut it on the center stand with the engine not running. Then rotate the tire by hand. Can you still hear it? Start it u. Can you hear it? If you said yes, remove the belt cover and start checking.
2400 miles is early for bearing failure.
