Part does not exist
Posted: Sat Jan 14, 2012 7:28 pm
by TikiMan
Ive looked at two websites and the gentleman at Honda could not locate it on his screen. Im looking for the rear brake pin that bolts through the transmission. Not the one that attaches to the brake cable, the stationary pin. Any clues where to look or can I just replace it with a bolt and seal it up with some rtv?
Re: Part does not exist
Posted: Sat Jan 14, 2012 7:40 pm
by evilone
That sucks...haven't heard of that one before. Did it break off or fall out? Just use the front brake?
Posted: Sat Jan 14, 2012 7:52 pm
by TikiMan
I had the cases sandblasted and when I got home and looked at it. I noticed that the peg was not there. Its not in any of my bags of hardware.
Posted: Sat Jan 14, 2012 8:24 pm
Which scooter?
Posted: Sat Jan 14, 2012 8:40 pm
by Red Eft Performance
TikiMan wrote:Ive looked at two websites and the gentleman at Honda could not locate it on his screen. Im looking for the rear brake pin that bolts through the transmission. Not the one that attaches to the brake cable, the stationary pin. Any clues where to look or can I just replace it with a bolt and seal it up with some rtv?
Number six in the diagram?
http://www.babbittsonline.com/honda-mot ... GS7XF0900B
Posted: Sat Jan 14, 2012 8:43 pm
by eliteguy50
If it is for your af05, I have an extra. Lmk.
Posted: Sat Jan 14, 2012 8:50 pm
Honda CAM, RR. BRAKE 43141-GR0-010 $13.96
It is used on 27 different models of the SA50 and SA50P.
Posted: Sat Jan 14, 2012 8:57 pm
by evilone
He said it's not the one that attaches to the brake cable, the stationary pin so i doubt it's #6. It's not even in the diagram. It's the pin on the other end of the brake pads.
Posted: Sat Jan 14, 2012 9:21 pm
by eliteguy50
The pivot point, right?
Posted: Sun Jan 15, 2012 1:06 am
by imomo713
Its called the anchor pin. Weird it has been overlooked in the parts microfiche, but I think that was common with alot of vehicles (no oem replacement parts) I would guess its a reused part throughout many models tho.
I dont think you'll be able to use a regular bolt since it bolts on the inside of the trans case, looks to have an o ring so that no oil leaks to other side of case.
edit: quick search has ebay link with pic, top left
http://www.ebay.com/itm/Honda-Elite-50- ... vi-content please note its for sb50 but they all look the same
Posted: Sun Jan 15, 2012 2:33 am
by eliteguy50
Yes, that is the one I'm thinking of.
Posted: Sun Jan 15, 2012 2:14 pm
by TikiMan
yep thats it. i have the cam it goes into the rear location but the front one is missing.
Posted: Sun Jan 15, 2012 2:16 pm
by TikiMan
But I also have a question about a little grove in the bearing raceway.
Posted: Sun Jan 15, 2012 2:34 pm
If that hole is between the bearing and the seal, it is an oil drain.
Posted: Sun Jan 15, 2012 2:51 pm
by TikiMan
So clean out the crude thats in it. check
