I dont get it
Mystic
I dont get it
Post by Mystic »
I suck at tuning hahahha setup polini contesta 21mm oko 45/100 stock pipe ruima vari with 9g 1.5k contra 1.5k grabbers with 9.1 gears 32:1 premix bp8hs plug 45 mph what am I doing wrong? heck my 43mm bore did 43mph
bakaracer
Re: I dont get it
Post by bakaracer »
mark the variator face with a sharpie and see how high the belt rides. what color is the plug? you using a cylinder head temp gauge?
Mystic
Re: I dont get it
Post by Mystic »
I havent really run it enough for a proper plug chop but so far it is a reddish brown on the end and black at the ring BUT its a used plug too so I will need to get a new one to really check it and no I dont have a cylinder head temp gauge I have a digital probe thermometer I stick on the side of the cylinder and on the head to get an estimate of the temps. measured around 290 after a short WOT run
switched to my prodigy with 9g and stock trans to eliminate that variable till I get the carb tuned, will mark the vari with a sharpie and drop to a 95 tomorrow and see where that puts me
evilone
Re: I dont get it
Post by evilone »
Hmmm, i did 58 mph with the stock carb :confused:
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Mystic
Re: I dont get it
Post by Mystic »
evilone wrote:Hmmm, i did 58 mph with the stock carb :confused:
I know that is what has me messed up hahahha
evilone
Re: I dont get it
Post by evilone »
Just curious what your compression ended up at.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Mystic
Re: I dont get it
Post by Mystic »
havent checked that yet :D it starts easy and has plenty of power on the bottom so I dont think that is my problem. Will check that tomorrow as well
Re: I dont get it
Post by swimmingfree »
did you put in upside down??????
lol olo
mark the variator like bakaracer said so you no if you using the hole thing.!!!
Mystic
Re: I dont get it
Post by Mystic »
I am pretty sure the belt is riding almost all the way out on the vari but will make sure tomorrow.
kingkamehameha
Re: I dont get it
Post by kingkamehameha »
Put a better pipe on and those 9:1 gears top out quick
kingkamehameha
Re: I dont get it
To small da carb and pipe go with a 24 or 26mm carb and get a better breathing pipe. You should think about getting 8.44:1 gears. Those jets are too small for 32:1 premix.
Mystic
Re: I dont get it
Post by Mystic »
Definately need a better pipe :D Just did a compression test 150psi cold. I did notice if i turned the a/f screw in all the way it ran better than at 1 1/2 out but I think the 45 pilot is too big. Think I may take the mani off and make sure my gaskets are good and seal the vacuum nipple screw
Mystic
Re: I dont get it
Post by Mystic »
What about the metal tabs on the reeds between the reed and the stop? would the fuel flow better with or without them?
Re: I dont get it
Without but the difference will only be a couple hundred RPM.
veedubh20
Re: I dont get it
Post by veedubh20 »
Contesta Does work well on sr stock pipe 8.4. Complete s tranny and 24mm carb :lol:
21oko need more fuel
On main jet that why turn red/light brown
