what's the harm of running a spree with no bystarter
Posted: Tue Apr 25, 2006 7:19 pm
by stankyoleman
what's the harm of running a spree with no bystarter on at all, just the empty port
Posted: Tue Apr 25, 2006 7:54 pm
by fizzle
do you mean blocked off port?
cause if its just open, i think that would be a serious vacuum leak, and it probably wouldn't run.
okay
well try it out and let me know
Posted: Tue Apr 25, 2006 8:27 pm
by Farfignugin
No bystarter w/ open hole: will not run!
No bystarter w/ plugged hole: Do not try this! I did and my scoot would NOT SHUT OFF! even with the kill switch off and key off! It also kept revving up! It only shut off by chance.
Posted: Tue Apr 25, 2006 9:56 pm
by MySpree
uhhh hey if u dont know then dont talk, my spree never had a bystarter till winter all summer it went without one. ran fast and strong to start all u had to do was put ur fnger over the hole and then once its on just take ur finger off and drive.
Posted: Wed Apr 26, 2006 1:22 am
by stankyoleman
wierd thing is, mine will actually start ok without one (i have a kickstart, no electric start), and a non-plugged port (completely open).
after it starts up, it idles real high, then back down alittle but still pretty high, and if i completely 100% block the hole with my thumb it dies.
reason i'm asking is because i have a bad bystarter, as in the needle is gone, and i think an o-ring might be warped possible... and i wanted to know what the best thing to do, because i don't seem to be getting as much out of the engine in terms of top end speed as i think i should.
Posted: Wed Apr 26, 2006 1:48 am
by stankyoleman
bottom line i was pretty much just trying to make sure that by not having a bystarter on my carb at all, broken or not, i wasn't damaging my engine in any way.
seems like it would only affect starting
Posted: Wed Apr 26, 2006 8:13 am
by MySpree
i was neer affected and i took my top end and cylinder of alot, so there was no piston damaga. i saw speeds of 40 mph on mine. ( cuz im coo like that )
Posted: Wed Apr 26, 2006 9:13 am
by Farfignugin
Never asume that what I say may not be correct! I just explained from experience thats all. My info. was not incorrect
Posted: Fri Apr 28, 2006 6:58 am
by noiseguy
Or Myspree's carb was just completely jacked up. Don't run w/o plugging the bystarter up with a pin, lots of air gaps and a fuel port there.
Posted: Fri Apr 28, 2006 8:20 am
by MySpree
nope me and my freinds were riding out sprees with no bystarters, it was fine we had no problems adn NON OF MY CARBS ARE JACKED UP! I BUILD THEM MY SELF AND I AM REALLY GOOD AT IT, I ALSO FIX CAR CARBS! SO I KNOW HOW TO FIX EM!
