Boost port
Posted: Thu Feb 02, 2012 11:44 pm
by kingkamehameha
Re: Boost port
Posted: Thu Feb 02, 2012 11:55 pm
by Mystic
Looks clean
What did you use to cut it?
Re: Boost port
Posted: Thu Feb 02, 2012 11:58 pm
by bonesv
Nice work, King! I did mine and then polished everything, then I learned that I shouldn't have polished anything. I sanded it all back to a dull surface again with 150 grit.
It's tuff work and my big hands hated it! Good luck with the build.
Re: Boost port
Posted: Fri Feb 03, 2012 12:10 am
by kingkamehameha
I used a carbon steel hacksaw blade and did it by hand with no saw just the blade. I got alot more control that way. I just made the blade about 6 inches long so it was easier to hold. I cleaned it up with a small tungsten file. I couldnt finish it all today. Needs a little more to be perfect
Re: Boost port
Posted: Fri Feb 03, 2012 6:45 pm
by evilone
Looks good.
Re: Boost port
Posted: Fri Feb 03, 2012 7:58 pm
by kingkamehameha
I took a c*** hair too much off. I need to open the boost on the bore just a tad
Re: Boost port
Posted: Mon Feb 06, 2012 11:58 pm
by Trafficjamz
C*** hair grows thick in hawaii.
Just messin' with ya.
What kinda bore is this?
Re: Boost port
Posted: Tue Feb 07, 2012 12:42 am
by kingkamehameha
Malossi bore. It was perfect before i went at it with the file d***!!!
Re: Boost port
Posted: Sun Mar 04, 2012 9:26 pm
by Downsouthdio
that extra little bit you went to much gunna matter?
Re: Boost port
Posted: Sun Mar 04, 2012 10:48 pm
by kingkamehameha
Downsouthdio wrote:that extra little bit you went to much gunna matter?
No because i opened up the boost port on my bore just a little
Re: Boost port
Posted: Tue Mar 06, 2012 5:21 pm
by Dio89Elite
looks pretty good!
what was your man hours to do the job? just wondering...
Re: Boost port
Posted: Tue Mar 06, 2012 7:03 pm
by kingkamehameha
Mabey an hour and a half
