CDI
memberzs
CDI
Post by memberzs »
will a new CDI really make a noticeable improvement on a 87 se50?
Carnie
CDI
Post by Carnie »
Nope, anyone here will tell you not to get an aftermarket cdi unless your stock one doesn't work. It's a waste of money.
1987 Spree
1994 Elite SR
Re: CDI
Post by eliteguy50 »
Unless you are dropping a few hundred on a Daytona (ignition advance).
Re: CDI
Post by swimmingfree »
and thay dont last as long as well ..so if you need one stock is the way to go
memberzs
Re: CDI
Post by memberzs »
no i just keep seeing their selling points as removing a rev limiter. if they truely wont help then im not going to waste my time on it.
Re: CDI
memberzs wrote:no i just keep seeing their selling points as removing a rev limiter. if they truely wont help then im not going to waste my time on it.
That applies to the true Dio, something we don't have.
Re: CDI
what is a rev limiter is the carb pipe and the port timing ...
Re: CDI
were are you going and is it a se50 or se50p ???
memberzs
Re: CDI
Post by memberzs »
its an se50p, so far i have a new vari and ramp plate, #88 jets, a new exhaust on the way, and 3.5" tire on the rear.
Re: CDI
do you have the 10/1 or 11/1 ??
what is your top speed ???
memberzs
Re: CDI
Post by memberzs »
11:1, my top as of now if 45, but i have yet to derestrict the exhaust. that will be done when it get here from fedex. i cruis around 40 though.
Re: CDI
dam thats grate top speed you may want to see if you can fine a 10/1 as for your rpm got to be hight do you no what it ??? hope mine dose as well i have the 10/1
memberzs
Re: CDI
Post by memberzs »
i have no idea what rpm im running at, id love to get a digital speedo and tach, but they are so damned expensive
Re: CDI
memberzs wrote:i have no idea what rpm im running at, id love to get a digital speedo and tach, but they are so damned expensive
Not that expensive if you skip the speedometer, beside you don't need the speedometer.
http://www.ebay.com/itm/360428804123?ss ... 213wt_1185
memberzs
Re: CDI
Post by memberzs »
Yeah ive seen those, and may get one, but i would really like a speedo also as im maxing my current one out when i ride to work.
