Stroker pipe
Posted: Mon Feb 27, 2012 2:08 am
by Jahden
Does anyone know if a pg long would be okay for a 120 stroker?
Re: Stroker pipe
Posted: Mon Feb 27, 2012 2:42 am
by bakaracer
yeah it will be fine if you already have the pipe and dont want to spend money on another pipe. plus you will have a wider power band than using a pipe for a 120cc setup which makes tuning easier. just take that insert thats welded in the tail pipe. just cut the 3 weld spots and the pipe should slide out.
Re: Stroker pipe
Posted: Mon Feb 27, 2012 3:45 am
by Dio89Elite
the pg long is one of the more well rounded exhausts for BBKs which is why they are quite popular, especially if you'll be running it more for the street than just pure racing.
Re: Stroker pipe
Posted: Mon Feb 27, 2012 3:58 am
by Jahden
Thanks Baka & Dio
