Oil Pump interchangeablity
Posted: Sun Apr 30, 2006 6:55 pm
by prattj1
Does anybody know what is different on these oil pumps? I have a sb50 that needs one and can only find spree parts. I still have my old one, including the shaft, but oil doenst come out. I am unsure how to check to see if it is working, other than see if oil gets pumped out. Has anybody taken one apart? Any Advice is highly anticipated.
Posted: Sun Apr 30, 2006 10:00 pm
by noiseguy
Probably interchangable... if it bolts up it should be fine. Do you have one on hand?
Posted: Tue May 02, 2006 2:11 am
by prattj1
Can anybody tell me how wide the spree oil pump is at the o rind that seats in the motor? Also, how much the shaft sticks out and how much goes into the pump?
Posted: Tue May 02, 2006 7:50 am
by MySpree
my freind has an sb50 elite and it has a spree pump on it, i have one if interested.
Posted: Tue May 02, 2006 9:16 am
by darat
remember the sa is the same as the spree engine so it should fit.
Posted: Tue May 02, 2006 9:52 am
by mopedman
it should fit, i have one, 10 bucks if you want it
