Bad spree, wont start. need help please!!!!!
Metosky
Post by Metosky »
I get spark.
I got compression.
I just put new rings in.
I cleaned the carb.
It was running, then it stopped.
The carb is getting gas.
Any ideas?
86ish honda sPree
hondaman
Post by hondaman »
It may be getting too much gas. Check your float. Check gas valve under your tank to make sure it is not stuck open. Try a new plug.
Metosky
Post by Metosky »
thanks i'll try that in the morring.
Forgot to put this in the original Post
And as of now i'm not getting any kind of reaction from the motor
No putter smoke or anything.
86ish honda sPree
MySpree
Post by MySpree »
hmmmm check the reed valves that would do that.
darat
Post by darat »
reeds dont normaly go bad on sprees. how many miles are on this spree. and u need to give us the year thanks..
mopedman
Post by mopedman »
what kind of oil you using?
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
niftyfifty
Post by niftyfifty »
i had all those things, mine turned out to be the bottom piston ring was continually stuck in... also check grounding wires to frame
Metosky
Post by Metosky »
The frame is a 86.
4500 miles.
The reed has a chip in it. But it is on the side.
So the reed is closed all the way around.
The cylinder is a 85. with ports opened a little.
I'll have to check the the parts frame.
The intake has been opened up to.
Breather for an airfilter.
It came with oil. it apears to be proper oil. blue.
The guy that at the honda shop said that I needed a 4 plug. it had a 6.
I put the new sparkplug in and it ran.
Around the block
Around the block
down the steet
Around the other block
Then I pushed it home
The plug was brown.
I think I got a weak spark. how do I check this?
The spark I got is a fine red line.
Should I get a new recoil? I got a high preformance recoil in this house some where. 500,000v or a 1,000,000v forget wich. Should I try that?
86ish honda sPree
hondaman
Post by hondaman »
The plug you should be using is a NGK BPR6HS. You should be getting a blue spark.
Blue oil isn't usually injector oil, the red stuff is. If you're not sure, dump/purge the blue stuff and refill with known oil.
MySpree
Post by MySpree »
blue is out board oil
deathwish
Post by deathwish »
i have blue oil and its 2 stroke injector oil... you cant always tell by color...best thing to do would be to buy new oil and drain the unkown oil out...
Wanna kno how to keep an idiot busy for hours look below
Wanna kno how to keep an idiot busy for hours look above
MySpree
Post by MySpree »
o well mine was blue and it was blue injector marine oil
Metosky
Post by Metosky »
What should the gap for the sparkplug be?
86ish honda sPree
Metosky
Post by Metosky »
I Got good oil now
Got a new NGK BPR6HS plug in.
how do I test what is giving me a bad spark?
86ish honda sPree
