Oil leak and Re-Jetting Carb 1987 Aero 50
Big AL
Post by Big AL »
Tks for the tip about fixing oil leak on my Honda Aero 50.. good call it was the hose so a $.89 clamp fixed that issue...ordered up a jet to match 65 cc kit...however Honda dealer could only get a 86 which is a slight up from the 82 but it is not a 90 as previously recommended....I ordered the 86 anyway figured a little more juice would not hurt..Also ordered up a air filter and a front lense..Never had a carb apart nor adjusted a carb before so it might be interesting...Should I spray inside to clean while I have it out ???
Big Al
