Spree graphics
DickB
Spree graphics
Post by DickB »
Now that I've got it running, I've been fooling with different graphic designs for my 87 Spree. If the yellow vinyl matches, I'm leaning towards this one. It has a bit of that 80s look to it. Maybe I should add "25th Anniversary Edition"!
spree slash 2.jpg (152.75 KiB) Viewed 7756 times
D i c k
87 Spree - 03 Reflex
http://www.carveshop.com
Re: Spree graphics
....Very sweet graphic concept... :thumbwink:
I see the addition of yellow grips being coup de grace (finishing "touch").... :smile:
DickB
Re: Spree graphics
Post by DickB »
Good idea - I did put yellow ones on my Reflex: viewtopic.php?f=6&t=22567
D i c k
OneBulletDan
Re: Spree graphics
Post by OneBulletDan »
SWEET! I like yellow and red together.
DickB
Re: Spree graphics
Post by DickB »
OneBulletDan wrote:SWEET! I like yellow and red together.
Did it before:
D i c k
DickB
Got 'er done
Post by DickB »
I like the way this turned out. I was thinking of doing something up front, but sometimes less is more, so I'm done. The headlight cover was a bit scratched up. I found that an Ace Hardware rattle can red matched fairly well. Look closely and you can see that the inner tube dust caps are a pair of dice. I initially thought that they were tacky and I would replace them, but what the heck - we'll see if anyone notices.
While the covers were off for the graphics I decided to clean the oil filter, although it turned out to be fine. So mechanically pretty much everything has been gone through and it's running well. All set for a road trip to NC next month.
This was a fun project. I'd get another one if I wasn't married or wanted to get a divorce.
spree slash.jpg (198.89 KiB) Viewed 7680 times
D i c k
dun rite
Re: Spree graphics
Post by dun rite »
turned out nice. doesn't the wife need a matching one?
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
Duke250
Re: Spree graphics
Post by Duke250 »
sweet nice ride. Both the car and the spree looks nice.
DickB
Re: Spree graphics
Post by DickB »
dun rite wrote:turned out nice. doesn't the wife need a matching one?
Thanks. Hmm, haven't seen the weather report - did h e l l freeze over? She wants nothing to do with two-wheeled vehicles.
D i c k
dun rite
Re: Spree graphics
Post by dun rite »
mine won't do motorcycles, but loves the elite and ruckus
arreche air filter
v8 pipe
stock gears
Re: Spree graphics
What you have done with this graphic [D ick B] is straight-up sharp... :thumbwink:
I would like to hear how this was created...can't tell if it is paint, sticker, voo-doo or what...
Your Spree is striking, I say work up a racing stripe for the front...sometime.... :urban:
Note: the censor program is prohibitting the use of this members username, * <<<thusly
DickB
Re: Spree graphics
Post by DickB »
Thanks. It's vinyl, cut using a Silhouette SD cutter, kinda like a printer with a blade. The software lets you import images and trace cut lines from them. For the Spree logo, I took a before photo of my scooter, cleaned up the image and fattened the lines a bit using a free drawing program paint.net, then imported to the Silhouette software.
A stripe for the front could look cool - we'll see.
D i c k
OneBulletDan
Re: Spree graphics
Painting the tranny case red instead of the raw aluminum would look cool, too.
DickB
Re: Spree graphics
Post by DickB »
OneBulletDan wrote:Painting the tranny case red instead of the raw aluminum would look cool, too.
It would. Maybe next winter.
D i c k
