Rear wheel
Downsouthdio
Rear wheel
Post by Downsouthdio »
Anyone ever noticed a slight wobble on their rear rim.. While riding?? Elite sr..?both of my buddys have a slight wobble when im riding behind them.. And today i put my rim on after putting my gears in.. Spun in and it does the same.. Kinda weird but ive seen it on a few now.. Anyone seen this!!?? :jack: :*:
Honda super dio
Corsa
26mm
Sparrow
Downsouthdio
Re: Rear wheel
And does anyone know if the honda metro. Wheel fits the eiite sr?
Honda super dio
Corsa
26mm
Sparrow
Re: Rear wheel
Post by swimmingfree »
i dont think is the rim its the tire that wobble..
SuprasNsprees
Re: Rear wheel
Post by SuprasNsprees »
swimmingfree wrote:i dont think is the rim its the tire that wobble..
when i aquired my spree, the previous owner didnt have the tire bead seated, and it had a serious hop/wobble
'80 Puch Magnum MKII
'78 PA50 Hobbit
Downsouthdio
Re: Rear wheel
Its deff. The rim.. I was spinning the rim
With no tire
Honda super dio
Corsa
26mm
Sparrow
Re: Rear wheel
The rims are stamped steel. Real easy to bend if ham-fisted tire-changer puts it in a machine.
The Met rim is both wider (2.15" vs. 1.85") and can run the tire Tubeless.
BTW a customer of mine recently suggested Lawn & Garden repair shops as a good place to have a tire installed if'n yer too Yella to try Wheelman's method in Tech Docs. They swap 6" and 8" and 10" tires all the time.
Downsouthdio
Re: Rear wheel
Thanks for the info..So id be able to run the 3.50-10 on the met rim??
Honda super dio
Corsa
26mm
Sparrow
Re: Rear wheel
Post by eliteguy50 »
Downsouthdio wrote:Thanks for the info..So id be able to run the 3.50-10 on the met rim??
fit on the met rim. Some brands will rub your case. A 90/90 is the safe bet, all brands will clear the af16 case.Yes, that size tire will
Downsouthdio
Re: Rear wheel
Yea ive always ran a 3.50-10 -- jus making sure with the met rim
Honda super dio
Corsa
26mm
Sparrow
Re: Rear wheel
The profile will change a little.
Downsouthdio
Re: Rear wheel
Sweet.. Theres a zillion riding around.. So im sure one of the shops will have one :wink:
Honda super dio
Corsa
26mm
Sparrow
HighSpeedDrift
Re: Rear wheel
Post by HighSpeedDrift »
Wheelman-111 wrote:Greetings:
So
So the Met wheel is not the same used on the elite? The Met looks identical in pictures. I was looking at my rim earlier today it looked like it could take a tubeless. I was going to get on here and ask can the stock wheel take a tubeless? or do they make a tubeless skinny enough for the stock rim if it can take one? My tube blew yesterday and my tire is about gone anyways. It would be nice to know If I could just pick up a tubeless tire and a valve stem tomorrow instead of a tire and a stupid tube...
1994 Honda Elite SR 9.1:1 gears, Keli variator, polini corsa, cr85 30mm carb, ct intake, zx trans. PG long exhaust.
1989 Honda Elite E 150cc GY6 (in the works)
2006 Yamaha R1 Raven
2006 Honda Crf450r Supermoto
1996 Honda z50
2007 Yamaha ttr50
2006 cr125
Re: Rear wheel
So
Some guys run tubeless tires on tt rims. I don't because the rim is not designed to hold a tubeless bead. The Metro rim is wider and has a different profile that is designed to hold the tubeless tire bead.
HighSpeedDrift
Re: Rear wheel
So
Ahhh thanks! Might as well get a tube tomorrow then to be on the safe side. BTW what do you mean when say tt? Sorry that very well could be a dumb question
1996 Honda z50
2007 Yamaha ttr50
2006 cr125
Re: Rear wheel
tt is short for tube-type. some tube-type tires will say tube type and others will say TT or tt.
