'85 honda upgrades?
abreen89
'85 honda upgrades?
Post by abreen89 »
i have a 1985 Honda spree stock ive spent the last month installing a new top end, and getting it to run stock now that i have it stock i want to get some upgrades on it because its not going much faster then 25 mph. What upgrades can i do to it without putting in a new engine? can i get better jets if so what #. and other performamce tips would be greatly appreciated.
'89 Honda Elite SB50p STOCK
'86 Honda Aero NB50 Stock
abreen89
Re: '85 honda upgrades?
Post by abreen89 »
can i run this elite intake..
http://www.ebay.com/itm/HONDA-ELITE-SB5 ... _601wt_908
and then get carbon fiber elite reeds
and run this spacer so i can keep the oil pump setup?
http://www.ebay.com/itm/HONDA-CH80-CH-8 ... 500wt_1416
if this set up will work can i keep the stock carb? and will this add alot of mph? (get me to 30+)
ragtop89
Post by ragtop89 »
You should get a hold of VT Cycles, and let them know what you would want to do.
83' Aero NH80
86' Yamaha Riva 125Z
abreen89 wrote:can i run this elite intake..
The manifold will work but it will not let the carb fit the airbox anymore.
The spare will NOT work. The mounting bolt spacing is too wide.
abreen89
Post by abreen89 »
does this performance cdi really boost your speed by alot say 5mph ?
http://vtcycles.com/vtc_plugins/e107sho ... t=30&cat=8
abreen89 wrote:does this performance cdi really boost your speed by alot say 5mph ?
NO! Save your money.
abreen89
Post by abreen89 »
k thanks bear what about elite manifold with carbon fiber reeds? will that boost my mph? and i there a way to keep the oil pump?
Sure the carbon fiber reeds will help but if you see 1 mph increase you will be lucky. Also losing the airbox means you have to rejet, not for performance but to keep from melting your piston from being to lean.
abreen89
Post by abreen89 »
abreen89 wrote:k thanks bear what about elite manifold with carbon fiber reeds? will that boost my mph? and i there a way to keep the oil pump?
bear wrote:Sure the carbon fiber reeds will help but if you see 1 mph increase you will be lucky. Also losing the airbox means you have to rejet, not for performance but to keep from melting your piston from being to lean.
i didnt say anything about losing my airbox do you mean that will help with performance? and can i run a elite intake and still keep the oil pump?
If you use the Elite manifold, which is a different length than the Spree manifold, the airbox will not fit anymore. So the oil pump question is moot.
abreen89
Post by abreen89 »
o i see. so if i run elite manifold, carbon fiber reeds, aftermarket air pod, and rejet will i get a few more mph or is it not worth it?
maybe, depending on what your expectations are.
abreen89
Post by abreen89 »
Bear45-70 wrote:maybe, depending on what your expectations are.
like i said im not breaking 25 mph. hopefuly we can figure out what jet i need tomorow. but im hoping to get low 30's
Before I started screwing around with the intake system or the engine itself, I would pull the left side cover and check the belt. Oh and if you scooter is an IOWA scooter, 25 mph is all it will do without derestricting it.
abreen89
Post by abreen89 »
alright i looked up my vin and my scooter is NOT an iowa spree but the exhaust i have was off someone elses scooter.. The restriction on a iowa spree is just a washer on the part of the muffler that connects to the cyliner? i looked and didnt see a washer and the hole that connects to the cylinder is the same size as the pipe so im pretty sure its not restriceted.
