Variator Pulleys too smooth?
ragtop89
Post by ragtop89 »
Well, I went for a good ride today, love the back roads out here. Anyway, I noticed by Aero 80 had trouble pushing 37 SOMETIMES. Any other time I can hit 40 for the first burst quite easily. I did remember however, that when I put my new belt on and had the variator off, I might have sanded it smooth to get debris off it thinking that would help... :roll:
I'm assuming now, that this is causing my belt to slip up on the variator at high speeds? Would using a rough grit to get the grip back on my variator pulley be a good temporary solution? Or am I screwed..
83' Aero NH80
86' Yamaha Riva 125Z
Re: Variator Pulleys too smooth?
too smooth? never heard of that.
stretched belt or oil/grease on the variator face could cause it to slip.
ragtop89
Post by ragtop89 »
I'll check into that, thanks jamz
83' Aero NH80
Post by eliteguy50 »
Roughing it up will just wear your belt. If the belt is slipping, then your contra is too weak.
ragtop89
Post by ragtop89 »
Yeah, thinking about it, I don't really think it's slipping then. Dunno why it doesn't want to hit 40 sometimes though, even on flat ground. Going down a hill, it wouldn't really push 40+.
83' Aero NH80
