LED street glow 85 spree
asakite91
Post by asakite91 »
I just put in a street glow strip on my spree. I got all the parts I needed on Ebay for under $10.
photo 2.JPG (29.19 KiB) Viewed 6587 times
photo 1.JPG (40.16 KiB) Viewed 6587 times
1985 Spree
ragtop89
Re: LED street glow 85 spree
Post by ragtop89 »
Love it! :thumbsup:
83' Aero NH80
86' Yamaha Riva 125Z
damnSA50
Post by damnSA50 »
Its a Super Spree! I got blue LEDs in the mail on saturday, I dig the blue lights!
deuce217
Post by deuce217 »
Nice work! You should get a red one also and have them on strobe patern, you might pull some chick up on the road!
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
Dio89Elite
Post by Dio89Elite »
awesome price for awesome looks! :thumbsup:
all that light coming from one glow strip?
Ewestfall
Post by Ewestfall »
Looking good!!!
paulpauly7
Post by paulpauly7 »
really? :shock:
asakite91
Post by asakite91 »
Dio89Elite wrote:awesome price for awesome looks! :thumbsup:
yep, just that one in the pic
1985 Spree
LMH
Post by LMH »
Having led or any other kind of lights on while driving here can get you a ticket. At least you did what I did and added a switch. I use the switch on the ground side to avoid having power going through the switch and avoiding a risk of a fuse blowing. I hope you used a fuse in line.
LMH
Post by LMH »
A poor pic due to downsizing it to fit.
LMH
Post by LMH »
I like the sprees body style more than the elites, you should get 2 more strands and put them inside the front wheel well and the rear like mine and itll give it a halo all around. Nice spree btw!
LoveMyHonda wrote: I use the switch on the ground side to avoid having power going through the switch and avoiding a risk of a fuse blowing.
Current flows through the switch no matter what side of the circuit you put it on.
LMH
Post by LMH »
You can ground out or " short" it and it won't matter if its a ground fed switch lol. Try that with a positive fed.
stucinthe80z
Post by stucinthe80z »
led strip will us a very small current you can run ten of them on a one amp fuse well before you blow the 7 amp fuse that powers you spree.
LMH
Post by LMH »
If youre hooking up extra things off of the battery save yourself some real problems and use a separate fuse, dont be cheap and screw up your regulator when your wiring grounds out.
Fuse holder -7.99 and readily available at wally worlds universal
regulator - 24.99 used and weeks or at least days to get the replacement.
Use your brain and put a fuse in line with any extra crap.
