NEED A FAST SPREE HELP PLEASE
rob_plum
Post by rob_plum »
I bought this 86' Spree from a guy down the street it runs and get around fairly well but i want this thing to be my little hot rod. Where can i buy an aftermarket exhaust and is the big bore kit with stage 2 gears on ebay the way to go or is there a company or person on here i can buy direct from to make this thing a hog. Please give me any info you have on this. much appreciated!!
Re: NEED A FAST SPREE HELP PLEASE
It's like this rob_plum...Spree motor will never be transformed into "hog".....save your $ and get a bike that has potential. The proven way to make Spree "hot rod" is to swap in a different motor. Not trying to discourage you from enjoying Spree, but bring your expectations to a realistic level.... :hi:
SpreeMadness520
Post by SpreeMadness520 »
I turned my spree into a monster with just over 1k :thumbwink: it all depends on how much your willing to spend!
130cc Stroker
1984 Porsche 944
1965 Vespa
rob_plum
Post by rob_plum »
I am using this thing to ride to school and work just to save gas I'm a wounded vet just making this a little project but i need this spree to get up and go a little... There are 4 of us that ride together a couple times a week for fun, its just a good time. I do not want to swap out anything I just want to know where to buy the kits for this spree and who to talk to...so if you could kindly direct me in the way of where to get everything i need to make this thing a little quicker i'd appreciate thank you.
rob_plum
Post by rob_plum »
I have seen these kits online and was wondering if it would truly make a difference and then i read on here about this tazland but cant seem to find anywhere to view his products.. I'm willing to put about 500.00 into it
http://www.ebay.com/itm/Honda-Spree-Eli ... _500wt_986
chopchop123 on ebay and taz are the same person.
That stage 2 kit will get you a little more power and the gears will help your top speed a bit.
The ebay seller chopchop*123 IS tazland001...you ARE looking at his product...it is quality...it will increase performance...it may not get you the "hog" you want, but I can't give specifics. Good luck, really... :hi:
rob_plum
Post by rob_plum »
well there we go. I guess this little spree will be up and zipping around in no time.
paulpauly7
Post by paulpauly7 »
motor swap is the best option to build a hog of a spree
SuprasNsprees
Post by SuprasNsprees »
Just did the stage 3 and pulley mod on mine and it only does about 39 mph. Pulled REAL hard without the pulley mod but still only got to 34mph on the kit
Hope this helps
'80 Puch Magnum MKII
'78 PA50 Hobbit
paulpauly7
a custom exhaust will bring the stage 3 kit alive
rob_plum
Post by rob_plum »
where can i buy this stage 3 kit and everything also a custom exhaust
SuprasNsprees
paulpauly7 wrote:a custom exhaust will bring the stage 3 kit alive
I'm sure of it.
'78 PA50 Hobbit
Post by eliteguy50 »
SuprasNsprees wrote:Just did the stage 3 and pulley mod on mine and it only does about 39 mph. Pulled REAL hard without the pulley mod but still only got to 34mph on the kit
Hope this helps
What exhaust are you using?
rob_plum wrote:where can i buy this stage 3 kit and everything also a custom exhaust
Send tazland001 a PM. The custom exhaust you will have to make or find someone to make it. We don't have a go to guy for exhauusts.
