stage 3 spree. need a pipe!!!
- SuprasNsprees
hard to believe there are engine/carb/gear sets available but not an exhaust pipe.
started riding with some hardcore 2t dudes, and figured something out real quick. no one has the stock pipe on their bike and it feels like a huge step was skipped
so, i'm very handy with a welder and metal fab, but i really don't have the 2t know-how to make one from scratch. so i started thinking about using the stock spree pipe from the flange down 8-9",and weld another pipe from an Elite or something to it
any thoughts?
any thoughts?
'80 Puch Magnum MKII
'78 PA50 Hobbit
'78 PA50 Hobbit
- paulpauly7
Re: stage 3 spree. need a pipe!!!
you can only but try
having no cvt you will be able to hear and feel when your pipe kicks in and work from there.Be prepared for more cutting and welding than you expect
- kingkamehameha
viewtopic.php?f=8&t=3464
You should read the advanced tech doc section before posting questions like this
Nah, thats why there are dogs like you to fetch stuff for people.
- SuprasNsprees
I posted looking first-hand experience. It's hard to talk down your nose at somebody when you can't repair a damaged tab on a pipekingkamehameha wrote:viewtopic.php?f=8&t=3464
I really like the look of the V8 pipe. Think I might try that
'78 PA50 Hobbit
'78 PA50 Hobbit
- SuprasNsprees
Think I'm going to try this
https://www.treatland.tv/big-large-giga ... hamber.htm
'78 PA50 Hobbit
'78 PA50 Hobbit
I would start higher on the spree header than 9", that will still limit your top end.
- kingkamehameha
You really want to talk smack boy? Look at your spree build and look at mine. I dont even need words to put you in your placeSuprasNsprees wrote:I posted looking first-hand experience. It's hard to talk down your nose at somebody when you can't repair a damaged tab on a pipekingkamehameha wrote:viewtopic.php?f=8&t=3464
- Downsouthdio
Im not 100% sure , but you guys might want to call moped hospital for an exhaust .. Or id just use the tenigas for the af16 to work with if your going to cut and weld.. But like i said call moped hospital here in key west.. They might have something.. Also anyone looking for arreche 19mm carbs For the stock af16 manifold can call them.. They have all the jets to.. Tecnigas pipes for the af16 as well..
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
- SuprasNsprees
kingkamehameha wrote:You really want to talk smack boy? Look at your spree build and look at mine. I dont even need words to put you in your placeSuprasNsprees wrote:I posted looking first-hand experience. It's hard to talk down your nose at somebody when you can't repair a damaged tab on a pipekingkamehameha wrote:viewtopic.php?f=8&t=3464
you did an engine swap, you stupid a*s. lol
apples/oranges. spend less time being an a*ss, and more time learning fabrication BASICS
eliteguy,and Downsouth. thanks, for not being a Queenkamehameha. i'll call moped hospital
Last edited by SuprasNsprees on Wed Apr 04, 2012 12:17 pm, edited 1 time in total.
'78 PA50 Hobbit
'78 PA50 Hobbit
http://www.fentonpowersports.com/
http://www.vespastl.com/
http://maplewoodscootercompany.com/
try fenton first, the guy is a really nice guy and if he doesnt have anything he can order it for cheap.
http://stlphins.com/slsc/index.php
good people to help you locally
- SuprasNsprees
i'm part of that board, but they all seem to be in the BIG scooters. i'll certainly ask thoughdamnSA50 wrote:http://stlphins.com/slsc/index.php
damnSA50 wrote:http://www.fentonpowersports.com/
cool,man. i'll make some more calls
left a message with Moped Hospital, but they seem to have forgotten to call me back
'78 PA50 Hobbit
'78 PA50 Hobbit
I don't know you called them but its only 7:40am in HI.
