Does any one know if the 1984 Gyro cylinders are interchangable with the 1985 and 1986
Gyro Cylinders? Thanks, Kev
Gyro Cylinders
Re: Gyro Cylinders
While not identical in port timing, 84 can interchange with 85/86.
You can see the differences here.
In work Gyro wiki page link
Re: Gyro Cylinders
Thanks Mousewheels for the info.
Kev
Kev
Re: Gyro Cylinders
mousewheels,
can you please point me to the thread where you posted photos of the aero cylinders with gyro cylinders? im trying to find an alternative. A friend has a gyro that needs cylinder, do you have any advice on this matter? I figure some modification will be required, im hoping to modify an aero jug and get this thing running again.
thanks
thanks
Re: Gyro Cylinders
Link to comparison of Spree/Aero/Gyro cylscan you please point me to the thread where you posted photos of the aero cylinders with gyro cylinders?
There is interference between the Aero exhaust port and the Gyro case. The Aero cyl also points the exhaust over to the case wall by the stator side. Some creativity and talent might pull off a mod. Post pics if you have ideas or get to work on this!
