Hi everyone:
Getting my 2000 elite sr in order. Put a new carb on in the fall and have already replaced bent throttle needle. Wondering if anyone has advice about my high idle. It's insanely high. I have to kill it after a few seconds. Idle screw does nothing so I'm guessing my problem is the throttle needle, but not sure.
Ridiculously high idle - Idle screw has no effect
- Trafficjamz
Re: Ridiculously high idle - Idle screw has no effect
the slide is not sitting all the way down in the carb.
possible that is in backwards.
lol Yeah, again, make sure the long open slit on the valve is facing away from you.
- kingkamehameha
Or you have a huge air leak
Thanks everyone. I'll report back after trial and error.
Throttle cable was incorrectly installed. Idle still high but not ridiculously high. Ran for a couple minutes then when I hit brake she stalled and didn't want to start back up. Thanks again. Will keep fiddling.
