RIK Brand Piston and Rings-any good?
Posted: Tue Apr 10, 2012 7:03 pm
by NateHimself36
I am re-building my 85' spree and i saw a new piston and rings for 48 bucks on ebay. They are RIK brand.The price didnt seem too bad at all so i bought it. It is stock size. Before it gets here and i make a mistake from putting in a worthless piston has anyone else used this brand before? it looks decent in the picture but that doesnt meen anything. Thanks-Nate
Re: RIK Brand Piston and Rings-any good?
Posted: Tue Apr 10, 2012 8:15 pm
by speedy25
From Chop chop right?
I bought one of these. Quality seems OK. Its in my running scooter right now with no problems.
-SP
Posted: Tue Apr 10, 2012 8:29 pm
by Trafficjamz
The RIK pistons and rings are used in the 44mm and 48mm bbk
I have RIK pistons in one of my race scooters.
The RIK rings will not fit the stock piston because they are too thick.
Posted: Tue Apr 10, 2012 8:47 pm
by NateHimself36
yes from chop-chop. I ordered the RIK piston and rings because i knew that the rik rings would not fit on the stock piston. Also, i am converting to a pre-mix setup so i can eliminate my oil pump but i do not have any idea on where the vacuum lines go. I have never worked on one of these until now. Thank you for your help-Nate
Posted: Tue Apr 10, 2012 8:55 pm
by Trafficjamz
the only vacuum line goes from the intake to the fuel petcock.
the extra nipple on the intake that used to be for oil needs to be blocked off so that the engine does not run lean from an air leak.
The oil pump can be looped back to itself or removed all together.
Why are you taking out the oil pump?
Posted: Wed Apr 11, 2012 1:53 am
by NateHimself36
ok cool thank you.
Posted: Wed Apr 11, 2012 2:00 am
by deuce217
Chop Chop is on this site also. His name is Tazland. I had great success with his BBK, gears, and carb. He knows his stuff.
Posted: Sat Apr 14, 2012 7:40 pm
by NateHimself36
oh cool i didnt know that was taz. i have heard alot of him on this forum. I am almost done with my re-build. I am finishing my engine painting, modded pocket bike exhasut, piston,rings,gaskets, i honed the intake and exhaust, super-cleaned the carb..i just hoooope it runs lol. in the next week i am going to paint the plastics and finish up the spree
ill post pics when im done
Posted: Sun Apr 15, 2012 11:15 pm
by NateHimself36
